In your opinion what are the most elegant physical processes?
  • Thread starter levelzdey
  • Tags
    Physical
In summary, the conversation discusses different examples of elegance in physical processes, from electromagnetic fields and wave formation to biological systems and energy production through solar technology and algae. There is a general agreement that elegance can be found in unexpected and surprising solutions, as well as in the efficiency and sustainability of certain processes. The use of concentrated solar energy to produce hydrogen and carbon black, and the potential of algae as a source of biodiesel and other applications, are highlighted as particularly elegant examples.
levelzdey
These can be classical or quantum. There is no correct "answer" and everything is based on your preference.
But in general let us stick to "elegant" processes which arise as "surprising" or "very easy to understand" solutions regardless of how complex the underlying equations and formulations are.I'll start things off with:
Synchronization
Here are some awesome videos related to the topic:
A demo video
Strogatz TED Talk
I think this should be posted in the General forum.
I like the way a magnetic field creates an electric field and vice-versa and how they form a wave :smile:
Surprising
Negative mass - for electrons moving in a wire [IIRC]
Using the Liénard-Wiechert potential for a moving charge: The electric field vector due to the charge, for an observer, points towards [or away from] the charge's present position, even though the retarded potential is used as the basis for the calculation.
Life itself, and the complex networks that you find in an ecosystem.
I see no elegance in this dusty world. Only in the smoothed out equations that physicists use to model it.
My personal favorites are estuarine wetlands. I wanted Marine Biology after I first saw a grainy video of pro, meta, ana, and telephase. ...but the economic draft of the mid-80' made me choose being a Marine instead. At least I was always near the ocean.
sensing in living beings, in real times.
I like how one composes his life his way and form a symphony without realizing it... Is this related? :biggrin:
came to this thread to say what's already been said: biological systems are the most elegant physical systems from a not-what-Jimmy-Snyder-meant way. That is, the emergent properties of biological systems that we observe are what's elegant. That life can find so many different permutations of perpetuation (i.e. homeostasis) with a finite set of "master genes".
It is even quite possibly an objective statement to say that biological systems are the most elegant systems in the universe.
But then, biological systems are also not closed systems, they are required to output heat (entropy) and take in nutrients to maintain homeostasis. They are coupled strongly to their environments, some of which are other biological systems, some of which are geophysical systems (atmosphere, ocean) and some of which are periodic energy sources (the sun and tides).
Elegant
Background – The SOLHYCARB proposal addresses the exploration of an unconventional route for potentially cost effective hydrogen production with solar energy. The novel process thermally decomposes natural gas (NG) in a high temperature chemical reactor heated by concentrated solar energy. This process results in two products: a H2-rich gas and a high-value nano-material, carbon black (CB). H2 is thus produced with renewable energy. Solar energy is stored as a transportable fuel. The fuel has zero CO2 emission: carbon as opposed to CO2 is sequestered. Fossil fuels are saved, and CB is synthesized.
This solar process is described in Figure 1...
http://www.pre.ethz.ch/research/projects/?id=solhycarb
Similarly, there is a great deal of elegance in using algae or bacteria to produce hydrocarbon fuels. This is why I am a great fan of using algae to produce biodiesel. Also, burning algae in closed systems to produce power might even make sense. From CO2 sequestration, to the production of carbon-neutral fuels for transportation, to the remediation of industrial and agricultural waste streams, to producing high-value feed for livestock, the algae energy option functions on many different levels. It is the most elegant energy option that I've ever seen.
The most elegant physical process?
That must be when a baby breaks into a smile..
FAQ: In your opinion what are the most elegant physical processes?
What is the definition of an "elegant" physical process?
An elegant physical process refers to a simple and efficient way in which a system or phenomenon operates. It is characterized by its simplicity and ability to produce desired results with minimal complexity.
Can you provide an example of an elegant physical process?
One example of an elegant physical process is the conservation of energy. This principle states that energy cannot be created or destroyed, only transferred from one form to another. It is a simple and efficient way to explain the behavior of energy in various systems.
How do scientists determine if a physical process is elegant?
Scientists determine the elegance of a physical process by analyzing its simplicity, efficiency, and ability to explain complex systems or phenomena. They also consider the level of complexity required to achieve the desired results.
Are elegant physical processes always the most accurate or reliable?
Not necessarily. While elegant physical processes are often simple and efficient, they may not always be the most accurate or reliable. In some cases, a more complex process may be needed to fully explain a system or phenomenon.
Can an elegant physical process be improved upon or changed?
Yes, elegant physical processes can be improved upon or changed as new information and data are discovered. As our understanding of the physical world evolves, so do our explanations and models of elegant physical processes.
