Inclined throw - motorcycle jumps from the ramp
In summary, to determine the minimum speed needed at the edge of the ramp for a motorcycle to reach the other side, one must consider both horizontal and vertical motion. The correct equation is V = -gt, and the time to reach a height of 1.5 meters is t = V₀/(2g). Taking into account the parabolic path and slight decrease in vertical velocity at the end, the minimum speed is approximately 54.7 km/h, rather than the initial estimate of 45 km/h.
Karol
1,380
Inclined throw -- motorcycle jumps from the ramp
The motorcycle jumps from the ramp. what is the minimum speed at the edge in order to reach the other side.
Constant acceleration: V=-gt
The time to reach height of 1.5 meters:
[tex]V_0\sin30^0=gt \rightarrow t=\frac{V_0}{2g}[/tex]
The horizontal distance:
[tex]V_0\cos30^0\cdot \frac{V_0}{2g}=10[/tex]
[tex]V_0=15.2 [m/sec]=54.7 [km/h][/tex]
And it should be about 45 [km/h]
Only if the motorcycle does not have a vertical velocity at the upper point. This is not true here. It will follow a parabolic path and "fall down" a bit at the end, this increases the time.
You'll have to consider both horizontal and vertical motion together.
Likes 1 person
First equation is wrong one.
Likes 1 person
Related to Inclined throw - motorcycle jumps from the ramp
1. What is an inclined throw in the context of motorcycle jumps?
An inclined throw refers to a technique used in motorcycle jumping where the rider launches off a ramp at an angle or incline, instead of straight up and down. This allows the rider to cover a greater distance and perform more complex tricks.
2. How does the angle of the ramp affect the motorcycle jump?
The angle of the ramp plays a crucial role in determining the distance and trajectory of the motorcycle jump. A steeper angle will result in a higher jump with less distance, while a shallower angle will result in a longer jump with less height.
3. What factors can affect the success of an inclined throw motorcycle jump?
Several factors can impact the success of an inclined throw motorcycle jump, including the angle and height of the ramp, the speed of the motorcycle, the rider's technique and skill, and environmental conditions such as wind and temperature.
4. Is an inclined throw motorcycle jump more dangerous than a straight jump?
Inclined throw motorcycle jumps can be more dangerous as the rider is launching off the ramp at an angle, which can increase the risk of losing control or crashing. However, with proper training and safety precautions, these jumps can be performed safely.
5. Are there any records for the longest inclined throw motorcycle jump?
Yes, the current record for the longest inclined throw motorcycle jump is 351 feet, set by Robbie Maddison in 2008. However, this record is constantly being pushed as riders continue to push the limits of motorcycle jumping.
