Including Coulomb interaction in a free energy calculation
In summary, the conversation discusses the addition of Coulomb interaction to a model of conductivity in a biological wire. The suggested approach is to incorporate this interaction as an additional term in the Hamiltonian and use statistical mechanics principles or computer simulations to calculate the free energy and understand its effect on the system.
barrozoah
Hi everyone!
I am trying to create a crude electron-hopping model to study conductivity in a biological wire composed of discrete sites. The model is pretty simple: imagine a line composed of sites. Electrons can hop from site to site with probabilities that depend on the free energy difference between those sites.
All these free energies were obtained numerically for the case where only one electron is in the system. Now I am considering the scenario where two electrons are in adjacent sites, and Coulomb repulsion would push them apart, changing their probability of hopping.
My question is how to add this extra Coulomb interaction to the free energy directly. I imagine that the internal energy and also the Hamiltonian change by a simple addition of a term, but I could not yet figure out how to account for an extra entropic difference that would be involved. Since I have the free energies obtained numerically for the case without this extra interaction, I wouldn't know how to decompose this back to a partition function so that it could be recalculated.
Thanks!
Hello!
Your question is an interesting one and it raises some important points about modeling biological systems. The addition of Coulomb interaction to your model is definitely an important consideration, as it can significantly affect the behavior of the electrons in the system.
One way to incorporate this interaction is to consider the Coulomb energy as an additional term in the Hamiltonian. This would be a potential energy term that takes into account the repulsion between the two electrons. In terms of the free energy, this would correspond to adding an additional term to the internal energy and subtracting it from the entropy.
However, as you mentioned, the challenge here is to decompose the free energy back to a partition function. One way to approach this would be to use statistical mechanics principles and consider the system as a canonical ensemble, where the number of electrons and their energy are conserved. This would allow you to derive the partition function and calculate the free energy for the system with the additional Coulomb interaction.
Another approach could be to use computer simulations to model the behavior of the electrons in the system with and without the Coulomb interaction. This would allow you to directly compare the results and see the effect of the interaction on the system's behavior.
I hope this helps and good luck with your research!
Related to Including Coulomb interaction in a free energy calculation
1. What is Coulomb interaction in free energy calculations?
Coulomb interaction, also known as electrostatic interaction, is the force between charged particles that arises due to their electric charges. In free energy calculations, it refers to the inclusion of this interaction in the calculation of the overall free energy of a system.
2. Why is it important to include Coulomb interaction in free energy calculations?
Coulomb interaction is a fundamental force in nature and can significantly impact the stability and behavior of a system. Inclusion of this interaction in free energy calculations allows for a more accurate and realistic representation of the system's behavior.
3. How is Coulomb interaction typically included in free energy calculations?
The Coulomb interaction is typically included through the use of the Coulomb potential, which describes the potential energy between two charged particles. This potential is then incorporated into the overall free energy calculation, often through the use of molecular dynamics simulations or other computational methods.
4. Are there any limitations to including Coulomb interaction in free energy calculations?
One limitation is the assumption of point charges, which may not accurately reflect the distribution of charge in a molecule. Additionally, the long-range nature of Coulomb interaction can make it computationally expensive to include in certain systems.
5. How does including Coulomb interaction affect the overall results of free energy calculations?
Including Coulomb interaction can lead to more accurate and realistic results, particularly in systems with charged particles or in the presence of an electric field. It can also provide insights into the stability and behavior of a system that may not be captured by neglecting this interaction.
