Inclusion-Exclusion Principle and Circular Arrangement
In summary, six people are sitting at a round table with six chairs. The host shuffles the seating arrangements and we have to find the number of arrangements where only 1, 2, or 3 people are happy. This problem can be solved using the inclusion-exclusion principle, which involves counting elements in subsets and accounting for overlaps. Another approach is to consider specific subsets of guests and use the principle to deduce the count for the full set. This problem may also correspond to permutations with forbidden positions.
Shahed al mamun
6 people are invited to a dinner party and they are sitting on a round table.
Each person is sitting on a chair there are exactly 6 chairs.
So each person has exactly two neighboring chairs, one on the left and the other on the right.
The host decides to shuffle the sitting arrangements.
A person will be happy with the new arrangement if he can sit on his initial chair or any of his initial neighboring chairs.
  1. We have to find the number of different arrangements such that only 1 person is happy.
  2. We have to find the number of different arrangements such that only 2 persons are happy.
  3. We have to find the number of different arrangements such that only 3 persons are happy.
Two arrangements are considered different if there is at least one person sitting on a different chair in the arrangements.
Can this problem be solved with inclusion-exclusion principle ? If so can anyone give me intuitive explanation of the solution process.
Before you can apply inclusion-exclusion you need to decide what your system of subsets is. E.g. if you could work out the answers for 'at least k are happy' then you could use it to deduce the answers to 'exactly k are happy'. But in this case I would think it is easier to answer the second question and deduce the answer to the first from that.
Another approach might be to consider specific subsets of guests, like 1st, 3rd and 4th from some starting point, independently of the rest. Having solved for each pair of the three, you may be able to use the principle to deduce the count for the triple.
The principle is really quite simple. You want to count the elements of some set. The set is spanned by some system of subsets, but these may overlap. If you count the elements of each subset and add them you will be counting some elements twice. To fix that you consider each pair of these subsets, count the elements in their intersection, and subtract those. But what if three of the subsets have a nonempty common intersection? You first of all counted those elements three times, then you subtracted them three times - once for each pair. So now you haven't counted them at all, and must add them back in... etc.
Joffan said:
Seems like your problem might correspond somehow to permutations with forbidden positions.
I believe that is identical to what I described as "another approach" in post #2.
Related to Inclusion-Exclusion Principle and Circular Arrangement
1. How does the Inclusion-Exclusion Principle apply to circular arrangements?
The Inclusion-Exclusion Principle is a counting technique used to find the number of elements in a set that satisfies certain conditions. In the context of circular arrangements, it can be used to find the number of ways to arrange objects around a circle while satisfying certain conditions, such as specific objects being next to each other or certain objects not being next to each other.
2. What is the formula for the Inclusion-Exclusion Principle?
The formula for the Inclusion-Exclusion Principle is: |A ∪ B ∪ C| = |A| + |B| + |C| - |A ∩ B| - |A ∩ C| - |B ∩ C| + |A ∩ B ∩ C|, where |A| represents the number of elements in set A, and ∩ represents the intersection of sets.
3. How is the Inclusion-Exclusion Principle used to solve circular arrangement problems?
To use the Inclusion-Exclusion Principle for circular arrangement problems, we first identify the sets involved, such as the set of all possible arrangements and the sets of arrangements that satisfy specific conditions. Then, we plug these values into the formula and solve for the desired number of arrangements.
4. Can the Inclusion-Exclusion Principle be applied to non-circular arrangements?
Yes, the Inclusion-Exclusion Principle can be applied to non-circular arrangements as well. It is a general counting technique that can be used for any type of arrangement problem, as long as the sets involved can be identified and the formula can be applied.
5. What are some common mistakes to avoid when using the Inclusion-Exclusion Principle for circular arrangements?
Some common mistakes to avoid when using the Inclusion-Exclusion Principle for circular arrangements are: forgetting to include all relevant sets, not taking into account the order of objects in the arrangement, and double counting arrangements. It is important to carefully identify all sets involved and to apply the formula correctly to avoid these mistakes.
  • Math Proof Training and Practice
  • Quantum Interpretations and Foundations
