Incompressiblitiy and unit length implies constants
In summary, the conversation is discussing the conditions under which two functions u and v in C^1(R^2) must be constants. The conversation suggests that if (u)^2+(v)^2=1 and u_x+v_y=0, then u and v are constants. However, this is not always true, as shown by the counter-example given. The conversation also mentions the idea of using the Cauchy-Riemann equations to prove this, but it requires the second equation which is not provided. Therefore, it cannot be concluded that u and v are always constants.
zhangzujin
Let [tex]u,v\in C^1(R^2)[/tex], and
[tex]
(u)^1+(v)^2=1,\partial_x u+ \partial_y v=0[/tex].
Then [tex]u,v[/tex] are constants.
Is it right? How to prove?
Any guys here knows? Thank you...
It's hard to tell what you are asking. "[itex]C^1(R^2)[/itex]" is the set of continuously differentiable functions in two variables but what are "(u)1" and "(v)2"?
Thank HallsofIvy for reminding...And (u)^2 is just the square of u, same as the meaning of (v)^2...
But your question has [itex](u)^1[/itex] not [itex](u)^2[/itex] ... was that an error?
What about (u,v) = (cos t, sin t) over all R^2?
Then what is "t"? Do you mean the [itex]\theta[/itex] coordinate in polar coordinates for the point (x,y)? In that case, [itex]\partial u/\partial v+ \partial v/\partial y[/itex] would not be equal to 0.
No, time. I am thinking in terms of fluid mechanics, where (u,v) is the velocity of the fluid (incompressibility suggested this to me). So the fluid is incompressible and has speed 1.
Otherwise I don't understand how the question makes any sense, "Then u,v are constants?"... constant with respect to what, if not time?
I mean if X=(u,v) =(u(x,y),v(x,y)) satisifies
1. |X|=1;
2. div X=0;
then X is a constant, i.e. idependent of x,y.
1. |X|=1;
2. div X=0;
Consider:
[tex] u(x,y) = \frac {-y}{\sqrt{x^2+y^2}},\ v(x,y) = \frac {x}{\sqrt{x^2+y^2}}[/tex]
[Edit] I just noticed your original post required continuity and this example isn't continuous at (0,0).
Year, the question is originated from vector analysis, then all functions are smooth, i.e. infinitely differentiable.Thank you.
Well, it's not always true (although I don't have a counter-example),
But it resembles the fact that analytic complex function with constant absolute values,
must be constant.
Here u and v play the roll of the real & imaginary parts of the complex function, and
the condition about the derivatives is one of the cauchy reimann equations. Problem is
you need the second one to complete the proof.
Let me show how I would start the proof, and then when I get stuck:
First of all, [tex]u^{2}+v^{2}=1[/tex] So at every point, either u or v are not zero.
No let's differentiate the equality wrt x and wrt y:
(I also divided the equations by 2)
[tex]uu_{x}+vv_{x}=0[/tex]
[tex]uu_{y}+vv_{y}=0[/tex]
So we have a system of equation wrt to u and v. But we also know that we have at each point a non-trivial solution, so the determinant must equal zero:
[tex]det(A)=u_{x}v_{y}-v_{x}u_{y}[/tex]
Now I only know that [tex]u_{x}+v_{y}=0[/tex], but it's not enought to complete the proof, beacuse I'd also need the other CR equation: [tex]u_{y}-v_{x}=0[/tex]
Then I could substitute this into the determinant condition and get:
[tex]u^{2}_{x}+u^{2}_{y}=0[/tex]
[tex]v^{2}_{x}+v^{2}_{y}=0[/tex]
Which implies
[tex]u_{x}=u_{y}=v_{x}=v_{y}=0[/tex]
So u & v are constant.
But you don't have the extra information, so generally it's not true.
FAQ: Incompressiblitiy and unit length implies constants
What is the concept of incompressibility?
Incompressibility refers to the property of a fluid or material that cannot be compressed or reduced in volume under applied pressure or force.
How does unit length relate to incompressibility?
Unit length is a measurement of distance or space. In the context of incompressibility, it means that the volume of a material remains constant regardless of the unit length used to measure it.
What does it mean when incompressibility and unit length imply constants?
This means that incompressible materials have constant volume and density, regardless of the unit of measurement used. In other words, the properties of these materials do not change with the scale or size at which they are observed.
What are the practical applications of incompressibility?
Incompressibility is important in many fields, such as fluid mechanics, materials science, and engineering. It is utilized in the design of hydraulic systems, pumps, and other machinery that require stable and constant fluid volumes. It is also a crucial concept in understanding the behavior of materials under pressure, such as in the construction of buildings and bridges.
Is it possible for a material to be completely incompressible?
No, it is not possible for a material to be completely incompressible. While some materials may exhibit highly incompressible properties, they will still have some degree of compressibility under extreme pressures. This is due to the inherent flexibility and deformability of materials at a molecular level.
