Incorrect derivation of tangential acceleration in polar coordinates
In summary, the conversation discusses the tangential acceleration of a particle and the equations involved in deriving it. However, it is pointed out that the equation ##a_T = \dot v_T## does not hold when unit vectors change position, and the reason for this is due to the mathematics in the original post.
yucheng
232
57
N/A
N/A
I am trying to derive the tangential acceleration of a particle. We have tangential velocity, radius and angular velocity. $$v_{tangential}= \omega r$$ then by multiplication rule, $$\dot v_{tangential} = a_{tangential} = \dot \omega r + \omega \dot r$$ and $$a_{tangential} = \ddot \theta r + \dot \theta \dot r$$ However, we also have $$\vec{a} = (\ddot r - r \dot \theta^2)\hat{r} + (r \ddot \theta + 2 \dot r \dot \theta)\hat{\theta}$$, which implies $$a_{tangential} = \ddot \theta r + 2 \dot \theta \dot r$$
Now, what's wrong?
You have essentially proved that ##a_T \ne \dot v_T##. The equation does not hold where the unit vectors change with position, hence time.
Hmmmm... Is there any way to make it hold when unit vectors change position? By the way, is there a reason why it does not hold?
You've proved it yourself. The mathematics in your original post is the reason.
  • Haha
Likes yucheng
Oops... ahahaha
Related to Incorrect derivation of tangential acceleration in polar coordinates
1. What is tangential acceleration in polar coordinates?
Tangential acceleration in polar coordinates refers to the rate of change of the magnitude and direction of velocity in a circular motion. It is measured in units of distance per time squared (such as meters per second squared).
2. What is an incorrect derivation of tangential acceleration in polar coordinates?
An incorrect derivation of tangential acceleration in polar coordinates is a mathematical calculation that leads to an incorrect formula for calculating the tangential acceleration in circular motion. This can happen if the correct formulas and principles of polar coordinates are not properly applied.
3. Why is it important to use the correct derivation of tangential acceleration in polar coordinates?
Using the correct derivation of tangential acceleration in polar coordinates is important because it ensures that the calculated value is accurate and reflects the true nature of circular motion. An incorrect derivation can lead to incorrect results and a misunderstanding of the physical phenomenon being studied.
4. What are some common mistakes in deriving tangential acceleration in polar coordinates?
Some common mistakes in deriving tangential acceleration in polar coordinates include not properly accounting for the changing direction of velocity in circular motion, using incorrect formulas for polar coordinates, and not considering the effect of centripetal acceleration on tangential acceleration.
5. How can one avoid making mistakes in deriving tangential acceleration in polar coordinates?
To avoid making mistakes in deriving tangential acceleration in polar coordinates, one should have a thorough understanding of the principles and formulas of polar coordinates, carefully consider the direction of velocity in circular motion, and double-check all calculations for accuracy.
