Incorrect lecture notes relating Bandwidth with speed?
In summary,The bandwidth of a signal is the spectral width of the signal. This is determined by how quickly the signal changes with time. The more data is sent simultaneously, the more bandwidth is required.
ericeng
Hello PF. Thanks for reading.
My understanding of Bandwidth in the context in which I learn it (Analogue and Digital Communications) is that it is the spectral width of a signal, BW = f[upper] - f[lower].
However, my lecture notes then define 'fundamental limitations' as,
Bandwidth:
- A measure of "speed"
- When a signal changes rapidly with time, the frequency content (or spectrum) extends over a wide range; i.e. has "large bandwidth"
- The faster data is sent, the more bandwidth it uses (is needed)
This confuses me. I don't get how bandwidth is a measure of speed, other than how frequency in general relates to signals in the time domain. Are the bullet points above factually correct?
How rapidly a signal changes with time only determines at which frequency(s) it lies, not the width of the range of frequencies?
I understand how sending data faster could require more bandwidth; by increasing bandwidth, more simultaneous signals could be sent. But to say that increasing the speed of transmission will result in an increase in bandwidth, I just don't understand that.
Insight is most welcome.
Thanks!
This isn't strictly true since a high frequency sinusoid "changes rapidly with time" but its spectral content is limited to a single frequency. It is, however, true for a trapezoidal waveform (which is a common approximation used for digital signals) - as you decrease its rise time, you increase the bandwidth (using your definiton) of the waveform.
I think its fair to say that higher bandwidth provides for more throughput. I understand "faster" in this context to mean an increase in data transmission rate.
What do you mean by 'speed of transmission'?
Okay, this I understand. Thanks.
So shouldn't this read that the more data sent simultaneously, the more bandwidth is required? Because the data could be being transmitted at the same rate but more data per unit time could result as an increase in bandwidth? ''Speed'' seems like the wrong word here. It's like suggesting "speed" is the cause of faster transmission due to a shorter cable.
Sorry, by speed I meant rate as you used above, not propagation speed.
If I saw those slides/notes, I would just think "speed" was used as a kind of umbrella term for rise time, data transmission rate etc. - just a way to get you to think of "things that move/change fast".
It doesn't strictly make sense but it _is_ presented in quotes ;)
Okay, thanks for your replies. I also came across the Shannon-Hartley theorem which defines channel capacity in bits/s. BW goes up, bits/s goes up. Simple!
Related to Incorrect lecture notes relating Bandwidth with speed?
1. What is bandwidth and how does it relate to speed?
Bandwidth is the maximum amount of data that can be transmitted over a network in a given amount of time. It is typically measured in bits per second (bps). The relationship between bandwidth and speed is that the higher the bandwidth, the faster the data can be transmitted.
2. Can a higher bandwidth result in faster internet speeds?
Yes, a higher bandwidth can result in faster internet speeds. This is because a higher bandwidth allows for more data to be transmitted in a given amount of time, resulting in faster data transfer rates.
3. Is there a direct correlation between bandwidth and speed?
While there is a relationship between bandwidth and speed, it is not always a direct correlation. Other factors, such as network congestion and the quality of the hardware and software being used, can also impact internet speeds.
4. Can a low bandwidth affect internet speed?
Yes, a low bandwidth can affect internet speed. If the bandwidth is not enough to handle the amount of data being transmitted, it can result in slower speeds and even connection issues.
5. How can I increase my internet speed if I have a low bandwidth?
If you have a low bandwidth, there are a few things you can do to potentially increase your internet speed. You can try optimizing your network settings, closing unnecessary programs and browser tabs, or upgrading to a higher bandwidth plan from your internet service provider.
  • Electrical Engineering
  • Atomic and Condensed Matter
