Sciencemaster
- 105
- 17
- TL;DR Summary
- I recently used a single 3D scintillator to collect cosmic ray muons. I'd like to find the flux, but because my detector is 3D, I end up with something of units different from flux.
I recently performed an experiment that involved using a cylindrical scintillator to detect cosmic ray muons by observing the amount of particles that decayed within 20 microseconds over a long period of time. I'd like to use this to find the flux of muons at my scintillator so that I can compare the results to other experiments done at different altitudes. However, because my experimental setup uses a 3D detector, I get something in terms of ##\frac{Hz}{cm^3}##, whereas every other experiment seems to get the expected units of ##\frac{Hz}{cm^2}##. Is there some operation I can perform on my result to find flux in terms of ##\frac{Hz}{cm^2}## despite having used a single 3D detector? Could I even find an accurate flux with this data, as I'm only considering particles that actually decayed within the scintillator?
