RTE
- 1
Hello all,
This is my first post, but I'm no stranger to skimming the boards. Always can find helpful stuff, but I'm stumped on this one. The situation is we have a Kohler 17 hp electric start gas engine horizontal shaft that max's out at 3600rpm. We are attaching a self-priming water transfer centrifugal pump to it that can handle the same HP, but it starts at 3600rpms and max's at 6000rpms... I want to get the most out of my pump so I have to increase the ratio on the pully system it will be attached to.. I am looking for a 1:3 minimum, but 1:4 would be solid... I'll stick with the 1:3 for now... My question is if I would attach let's say a 3.5" pulley to the pump and around a 10" on the engine then would the engine have a tough time starting up on it's electric start system with that big of a pulley attached directly to it? Engine shaft is 1 1/4" and pump shaft is 5/8".. Everything double belt or triple? The entire system runs on a 12v battery which is charged by the command pro Kohler engine... The system turns on and off automatically using murphy switches and a control panel... Any input would be most appreciated... Thanks
