Increase Electromagnetics emmission?
In summary: Is that what you were asking? Unless you launch an EM wave, the magnetic field will be confined to the...field. Is that what you were asking?
Toothless
First of all - I'm new here, and this forum looks awesome!
As for my post, I'm going to be using an inductor to emit an electromagnetic field, and was wondering if you could somehow either increase it or isolate the emission maybe via antenna? I know antennas are typically used to convert currents to waves, but could it suffice for this case?
Also, is an inductor the best way to emit an electromagnetic field?
Thanks!
~Toothless
PS: If this is in the wrong forum/sub-forum, sorry!
Thanks!
~Toothless
Welcome to the PF.
Can you say more about your application? Are you wanting to make a small localized oscillating magnetic field? Perhaps in a transformer gap or similar?
Or are you wanting to launch an EM wave to be received at some other station a distance away? What frequencies are you wanting to use? How far do you want to communicate?
Keep in mind that the RF spectrum is regulated by the governments of most countries, and you can't just go transmitting on any old frequency that you want. Licenses are required for most radio transmissions...
Welcome to the PF.
Oh sorry for leaving out some details. I'm basically wanting to make a small localized oscillating magnetic field as you said, for experimenting purposes. I'm curious as to how far I could extend its range. Also thanks for the welcoming.
What frequencies will you want to be using?
For small volumes, say about the size of a tennis ball, you can use a "C" shaped piece of metal (laminated iron for low frequencies, or ferrite for higher frequencies), where the tennis ball would fit in the gap of the C. You would wind your exciting coils around the long part of the C, to generate an oscillating B-field in the gap.
For larger areas (where it is not practical to have such a large C-shaped piece of metal), you can use a coil called a Helmholtz Coil:
http://en.wikipedia.org/wiki/Helmholtz_coil
to generate a fairly uniform B-field in the volume between the two coils.
Okay, thanks! Now what if I want to try and isolate the field instead of oscillation. Would I just use a simple Former using Copper Wire and a ferrite core?
Could you please re-state your question with more details? It's not translating very well.
With both methods you stated, a magnetic field will only oscillate in a limited area. Now what if I wanted to extend it outward toward an isolated direction.. perhaps just generally forward?
Unless you launch an EM wave, the magnetic field will be confined to the volume between the ends of the inductor. If you use a rod inductor instead of a C-shaped inductor, the field will spread out, but will be quite weak at a distance.
How could I launch an EM wave?
First you get a license for the band you want to transmit in. Then you build and test the hardware of your transceiver.
The point has already been made that you need to specify what frequency you plan to operate with. This is important because you you need to be using a 'legal' frequency and an appropriate radiating element.
If you don't have any idea about this and you want to make an operating system then you should start with a self assembly kit with circuit and instructions. (That is a quicker method of getting a result than learning it all from square one!)
Also, if you want to 'launch' a wave then you also need to be able to receive / detect it - or you won't know if the kit is working.
FAQ: Increase Electromagnetics emmission?
What are the potential health risks associated with increased electromagnetic emission?
The potential health risks associated with increased electromagnetic emission include an increased risk of cancer, changes in brain activity, and interference with medical devices such as pacemakers. However, the current scientific consensus is that the levels of electromagnetic emission present in our daily lives are not harmful to human health.
How can I protect myself from increased electromagnetic emission?
There are a few ways to protect yourself from increased electromagnetic emission, such as limiting your use of electronic devices and keeping them at a safe distance from your body. You can also invest in shielding devices, like special phone cases or laptop pads, that claim to reduce your exposure to electromagnetic fields.
What are the sources of increased electromagnetic emission?
The main sources of increased electromagnetic emission are electronic devices, power lines, and wireless communication technologies such as cell phones and Wi-Fi routers. Other sources include household appliances, electric cars, and even the Earth's natural magnetic field.
Are there regulations in place to limit increased electromagnetic emission?
Yes, there are regulations in place to limit increased electromagnetic emission. For example, the Federal Communications Commission (FCC) regulates the levels of electromagnetic emission from cell phones and other wireless devices. Power lines also have limits on their electromagnetic fields set by the Environmental Protection Agency (EPA).
Can increased electromagnetic emission affect the environment?
There is ongoing research on the potential effects of increased electromagnetic emission on the environment. Some studies have shown that electromagnetic fields can disrupt the behavior and reproduction of animals, such as bees and birds. However, more research is needed to fully understand the impact of increased electromagnetic emission on the environment.
