Increase in energy in an electric field
In summary, the conversation discussed the construction of Thomson's apparatus for determination of specific charge and the question of where the extra energy of an electron comes from when it leaves the area between two oppositely charged plates. It was suggested that the electron's kinetic energy remains constant throughout its trajectory, but its potential energy decreases as it moves closer to the positive plate. The conversation also touched on the concept of conservation of energy and how it relates to the motion of the electron in this system.
Mr.4
41
I was explaining the construction of Thomson's apparatus for determination of specific charge for an exam today and suddenly something popped up:
Consider 2 oppositely charged plates held using insulated handles (They're not connected to a battery). If an electron moving with a velocity v passes perpendicular to this field then it will experience a force eE causing it to accelerate towards the positive plate. Suppose v is such that the electron escapes the volume between the plates before it can reach the positive plate. Thus the electron leaving the area between the plates would have a greater kinetic energy because the magnitude of v vector would have increased. How can one account for this energy? The plates could not have lost any energy since they are not connected to a cell or allowed to move. And the net field outside the plate system would be zero from Gauss law. Then where did this extra energy come from?!
It's easy to see how to balance the momentum: the plates will be electrostatically pushed in the opposite direction, so claiming they aren't "allowed to move" just means the entire support is pushed as well. As for energy, which other of your statements may be faulty?
Gauss' law is only useful given a higher degree of symmetry, since the net field doesn't tell you what the field at every point is like. When the electron travels through the finite plate system, it first approaches from a little bit closer to the negative side (so, is a little repulsed from approaching at all) and leaves from a little bit closer to the positive plate (vainly attracting it to not leave at all).
So sure, the electron gains a second component to its motion. But since the first component of its motion is decreased in your scenario, you have not demonstrated that the electron escapes with any extra energy.
What happened to accounting for potential energies?
@cesiumfrog what if the electron is approaching symmetrically from infinity. There would be a point midway between the plates where potential is zero.
And are you sure that a considerably large apparatus would move?!
And no the first component is not decreased. The motion in the electric field is parabolic and analogous to projectile motion under gravity so that horizontal component always remains constant. But unlike projectile motion the electron doesn't come back to 'ground' level in projectile motion. I hope I'm clear.
Yes, but even if it approaches along that mid-surface, it will not leave along the same surface; the point is that the force as it departs will not be canceled by the force as it approaches.
Momentum is conserved, but for a large apparatus (compared to an electron) this produces neglegible velocity (and, in the limit, removes no energy). It is actually not relevant to your main question.
You are only considering the motion while the electron is between the two plates (and you are approximating those plates as infinite). You should also consider the motion when the electron is not between the plates (and notice that there will still be an electric field, which also isn't completely perpendicular to the plates).
I thought it would be redundant to quote the laws of thermodynamics, since I assumed you had realized that energy must be conserved (and therefore, the reasoning that suggested otherwise to you is flawed). Was I mistaken?
Of course I'm aware of the conservation of energy (and hence the question!). But do the math. I've referred multiple textbooks and they all suggest that when the magnitude of the leaving velocity will be greater anyhow. But back to my original question: Where does this energy come from?
From some of your statements I'm concluding that there must have been a net field acting on the electron against which we had to work to bring it to the initial path. This work would account for the increase in kinetic energy after moving through the field. Is that true?!
No, I was not considering whether work must be done to put the electron on its initial path; I'm arguing that the electron's initial kinetic energy (far before the plates) will be exactly equal to the electron's final kinetic energy (far after the plates). Hence, as no energy is gained, there is also no place for it to have come from. Since this seems to contradict what your textbooks suggest, would you mind giving the references?
Not unless the trajectory is symmetric with respect to the mid-plane normal to the plates and the plane of motion. The electron's total energy is conserved, not its kinetic energy. After entering the region between the plates, the electron exits in a manner that puts it closer to the positive plate (than the negative one). It loses PE as a result.
PS: Just noticed the qualifier "far", in which limit, the above statement is, indeed true.
yup, but now I realize what the textbook might have been saying. Sounds like Mr4 just needs to find a picture of the electric field outside of a (finite) parallel plate capacitor.
Duh, that's what i was saying in my previous posts. I'm referring some Indian textbooks namely HC verma and Nootan ISC physics (+2).
I agree with Gokul's statement but then what does the far have to do with anything if the K.E, P.E distribution is modified.
FAQ: Increase in energy in an electric field
What is an electric field?
An electric field is a region in space where an electric charge experiences a force. It is created by a source charge and can be represented by electric field lines.
How does energy increase in an electric field?
The energy in an electric field increases when work is done on a charged particle to move it against the electric field. This work is done by an external force and increases the potential energy of the charged particle.
What factors affect the increase in energy in an electric field?
The factors that affect the increase in energy in an electric field include the magnitude of the electric field, the distance over which the charged particle is moved, and the charge of the particle itself.
What is the relationship between energy and potential difference in an electric field?
The potential difference, also known as voltage, is directly proportional to the energy change in an electric field. This means that as the potential difference increases, the energy of the charged particle also increases.
How is the increase in energy in an electric field used in practical applications?
The increase in energy in an electric field is used in various practical applications such as charging batteries, powering electronic devices, and generating electricity in power plants. It is also essential for the functioning of electric motors and generators.
18K
