Increase in plasma energy from the increase in an ultraweak field
In summary, as B increases, Faraday's Law creates a circular E-field that accelerates ions and electrons into a gyrating motion. These gyrating particles have a magnetic moment that opposes the applied B-field, following Lenz's Law. When the B-field is decreased, a circular induced E-field decelerates the particles, reducing the magnetic moment and opposing the change in the B-field. The work done to increase the B-field must be returned to the mechanism that generated it, similar to current returning to a circuit in a RLC circuit after the inductor discharges. This returning current, in the form of a circular E-field, induces a voltage in the circuit. Ultimately, the circular E-field plays a crucial role in both
Veles
Consider a time-dependent magnetic field B(t). Let the variation be slow so that the magnetic moment is constant. Let B be made to decrease by a factor of two - say, due to plasma motions. If the field is in a uniform Maxwellian plasma and they are both in a cylinder of radius r, then the energy of the plasma must decrease by a factor of two. This is true even if the energy of the field is infinitesimal compared to the energy of the plasma, provided B(t) decreases slowly compared to the cyclotron period . Where does the extra energy go?
None
As B increases, a circular E-field is setup by Faraday's Law, which accelerates the ions/electrons into a gyrating motion. The gyrating electrons/ions have an effective magnetic moment that opposes the applied B-field (Lenz's Law). When the B-field is decreased, a circular induced E-field decelerates the ions/electrons, reducing the magnetic moment and again opposing the change in the B-field.
The work done to increase the B-field (part of which went into acceleration the electrons/ions, and part into the B-field density) must be returned to the mechanism that generated it. This is analogous to the current returning to the circuit in a RLC circuit after the inductor discharges.
The returning current (in the form of a circular E-field) induces a voltage in the circuit. Thus, as B increases, a circular E-field is setup. As B decreases, a circular induced E-field is setup, and this opposes the change in the B-field.
Related to Increase in plasma energy from the increase in an ultraweak field
1. What is plasma energy and how is it affected by an ultraweak field?
Plasma energy refers to the total energy contained within a plasma, which is a state of matter consisting of ionized particles. An ultraweak field is a type of electromagnetic field that is extremely low in strength. When an ultraweak field is applied to a plasma, it can cause an increase in the plasma energy.
2. How does an increase in an ultraweak field lead to an increase in plasma energy?
When an ultraweak field is applied to a plasma, it can cause the charged particles within the plasma to move and interact with each other. This movement and interaction leads to an increase in the total energy contained within the plasma, resulting in an increase in plasma energy.
3. Can an increase in plasma energy from an ultraweak field be measured?
Yes, an increase in plasma energy can be measured using various techniques such as spectroscopy, interferometry, and particle diagnostics. These methods allow scientists to quantify the changes in the plasma energy caused by an increase in an ultraweak field.
4. What are the potential applications of an increase in plasma energy from an ultraweak field?
The increase in plasma energy from an ultraweak field has various potential applications in fields such as plasma physics, astrophysics, and materials science. It can also be used in technologies such as plasma-based energy sources, plasma thrusters, and plasma-assisted surface treatments.
5. Are there any potential risks associated with an increase in plasma energy from an ultraweak field?
Yes, there are potential risks associated with an increase in plasma energy from an ultraweak field. These may include damage to electronic equipment, interference with communication systems, and potential harm to living organisms if exposed to high levels of plasma energy. Therefore, it is important to carefully control and monitor ultraweak fields in plasma experiments and applications.
  • Beyond the Standard Models
