Increase in the volume of a sound
In summary, when turning up the volume on a radio, both the maximum displacement and average speed of a point on the diaphragm must increase. This is because an increase in amplitude, or maximum displacement, would cause the point to travel farther and therefore take longer to cycle, resulting in distortion. To maintain the same frequency, the average speed must also increase.
EchoTheCat
A person turns up the volume on a radio. Which aspects of the motion of a point on the diaphragm must increase?
a. maximum displacement only
b. average speed only
c. both maximum displacement and average speed
d. neither maximum displacement nor average speed
speed = wavelength * frequency
I thought it would be (a), because in order for the sound to get louder, the amplitude must increase, but amplitude doesn't affect speed. so the answer is (c) and I'm not sure why.
I could be wrong, but the average speed of the diaphragm must increase in order to maintain the same frequency. If you increase the amplitude, the point will be traveling farther. If it traveled farther at the same average speed, it would take longer to cycle. An increase in the period would decrease the frequency and you would get distortion. Thus you need to increase the average speed of the diaphragm as well as the displacement.
Likes berkeman
Looks correct to me. :smile:
Related to Increase in the volume of a sound
1. How does an increase in volume affect the loudness of a sound?
An increase in volume generally results in an increase in the perceived loudness of a sound. This is because the amplitude, or maximum displacement of air particles, is greater when the volume is increased, resulting in a stronger and more intense sound.
2. What is the relationship between volume and amplitude?
Volume is often used interchangeably with amplitude, but strictly speaking, volume refers to the perceived loudness of a sound while amplitude refers to the physical measurement of the maximum displacement of air particles. However, an increase in volume usually correlates with an increase in amplitude.
3. Can an increase in volume damage hearing?
Yes, an increase in volume can potentially damage hearing if the sound is too loud or if the exposure is prolonged. This is because the increased amplitude can cause damage to the delicate hair cells in the inner ear, leading to hearing loss.
4. How is the volume of a sound measured?
The volume of a sound is typically measured in decibels (dB). This is a logarithmic scale that measures the intensity and loudness of a sound. The higher the decibel level, the louder the sound.
5. Why does the same sound seem louder in a smaller room compared to a larger room?
This is due to the phenomenon of reverberation. In a smaller room, sound waves bounce off the walls more quickly and frequently, resulting in a buildup of sound and a perceived increase in volume. In a larger room, the sound waves have more space to dissipate, making the sound seem quieter.
