Writing: Input Wanted Increasing albedo of dark volcanic plain
  • Thread starter Thread starter Nik_2213
    Albedo
A newly discovered 'greenhouse' planet features a volcanic shield with acceptable temperatures and an anoxic atmosphere rich in nitrogen and carbon dioxide, allowing for potential hydroponics and irrigation. The presence of silica sand enables the creation of glazing panels, while strategies to improve the local environment include scattering pale sand to enhance albedo and reduce daytime heat. The planet's water cycle is minimal, with night dew providing some moisture, but plants would require supplemental oxygen for respiration. Experimental test plots are proposed to determine the optimal size of sand granules for effective coverage without loss to the lava's irregularities. The discussion emphasizes the need for innovative solutions to support plant growth in this challenging environment.
Nik_2213
My heroes have found a barely-tolerable 'greenhouse' planet, the upper part of a vast volcanic shield having acceptable temperature and pressure (*). The anoxic atmosphere is N2+CO2, but holds enough H2O for nightly dew near the summit.
So, can condense that, use for hydroponics, irrigate green-houses etc. Electrolyse some water for oxygen for habitats and, yes, crops, as latter need it to respire through the night.
Beyond the volcanic massif, they have ready access to dune-fields of silica sand. In fact, they're smelting such to glazing panels...
There's a suggestion that long days' heating of dark, low-albedo volcanic plain surrounding the base might be 'improved', mitigated by scattering pale sand...
Clearly, 'raw' sand would tend to vanish down irregularities in the old lava, while 'ping-pong' or 'marble' spheroids may be too big, so wasteful...
Okay, the experimental approach is to lay out 'test plots' of different 'gauge' material, see how they compare. Is there a better way to estimate 'mini-max' benefit and predict the 'sweet spot' ?
*) Ambient pressure is 'SCUBA', with some helium in the habs' mix to mitigate the several Bar...
What does this mean?
No life already on planet?
Water condensing on the lava would tend to react with it an vanish from the atmosphere in a weathering process. This would tend to make it more useful for (earth) plants.
This means it get too hot?
Growing plants (if possible) on the surface would mitigate that.
Sweet spot for what?
Thank you for taking an interest in this topic.
The helium in the habs' breathing mix ? 'Technical' divers do this to mitigate oxygen / nitrogen toxicity.
Planet is anoxic, lifeless. That night dew shows there is still a meagre water-cycle. Not quite enough CO2+H20 for a 'runaway' greenhouse unto full Venusian. The next major shield eruption might achieve this, or perhaps the one after...
Yes, the old,, dark ;ava fields get too hot by day. Yes, growing plants would help. Snag, atmosphere is anoxic, and plants need some oxygen to respire in the dark. So, plants restricted to indoor hydroponics, or outdoor cloches / greenhouses with supplementary oxygen.
Spreading pale sand around would raise the local lava-field's albedo, staying cooler by day should mean faster cooling by night.
Snag, sand as-is would soon vanish down the old lava's irregularities. They already process silica sand to granules for 'ponics and greenhouse plantings. What size would be optimal for coverage ? Too small is lost, too large, whatever that size, is wasteful. So, how to figure the likely 'sweet-spot' ??
Google up 'glass wool'.
With some handwavium you can scatter it 'on the fly' too (look up the manufacturing process).
Also can serve as a soil-replacement for plants (though rock-wool is more frequently used for that purpose).
Likes BillTre and Nik_2213
I was inspired by Jane Hawk trilogy of Dean Koontz. The villains injected people with brain control nanobots, and the possessed humans could form a hive mind. The villain try to do something similar in my story, that is supposed to be rather scientifically realistic, not space fantasy. On the other hand, she cant inject all the people in a town, the nano have to get in by drinkwater, so only a tiny amount for each victim. Is it a bottleneck, how the possessed people will be able to receive...
Earth has one large natural satellite in reality. This is only talking about the context of a habitable, planet that has the conditions as Earth, with similar axial tilt. It would have a moon system similar to that of Uranus. Let's say it has 6 moons, similar in size to Puck, Miranda, Ariel, Umbriel, Titania, and Oberon. These 6 moons would orbit in safe, stable orbits around the Earth-like planet. What would their apparent size, and realistic distance be from the Earth-like planet? What...
