Increasing and Decreasing Numbers
Therefore, there are always 9 times more increasing or decreasing numbers than their n-1 digit counterparts.In summary, there are 8 increasing 3-digit numbers, 36 increasing 4-digit numbers and (n-1) x 9 increasing or decreasing numbers for any n-digit number.
eddybob123
178
Intended for high school students:
Let a positive integer be called "increasing" if every one of its digits is strictly greater than the one directly to the left of it. For example, 289 is increasing but 6788 is not.
How much 3 digit increasing numbers are there?
How much 4 digit increasing numbers are there?
How much n digit increasing numbers are there?
(Note: a number can't start with 0.)
Likewise, call a number "decreasing" if every digit is less than the digit directly to the left of it.
How much n digit decreasing numbers are there?
Mathematics news on Phys.org
3 Digit Increasing Numbers:
There are 8 increasing 3-digit numbers, which are 123, 124, 125, 134, 135, 145, 234, and 235.
4 Digit Increasing Numbers:
There are 36 increasing 4-digit numbers, which are 1234, 1235, 1245, 1345, 2345, 1236, 1246, 1256, 1356, 1456, 2356, 2456, 1237, 1247, 1257, 1357, 1457, 2357, 2457, 3457, 1238, 1248, 1258, 1358, 1458, 2358, 2458, 3458, 1239, 1249, 1259, 1359, 1459, 2359, 2459, 3459, and3459.
n Digit Increasing Numbers:
For any n-digit increasing number, there will be (n-1) x 9 such numbers. For example, for a 5-digit increasing number, there will be 4 x 9 = 36 such numbers.
n Digit Decreasing Numbers:
For any n-digit decreasing number, there will be (n-1) x 9 such numbers. For example, for a 5-digit decreasing number, there will be 4 x 9 = 36 such numbers.
FAQ: Increasing and Decreasing Numbers
What is the difference between increasing and decreasing numbers?
Increasing numbers refer to a sequence of numbers that are getting larger in value, while decreasing numbers refer to a sequence of numbers that are getting smaller in value.
How do you identify an increasing or decreasing number pattern?
To identify an increasing or decreasing number pattern, you can look at the difference between each number in the sequence. If the difference is positive, the numbers are increasing. If the difference is negative, the numbers are decreasing.
What are some real-life examples of increasing and decreasing numbers?
A real-life example of increasing numbers could be the population of a city over time, as the number of people living in the city increases. An example of decreasing numbers could be the amount of money in a bank account, as money is spent and the balance decreases.
How can you calculate the rate of increase or decrease in numbers?
To calculate the rate of increase or decrease in numbers, you can divide the difference between the final and initial number by the initial number. Then, multiply the result by 100 to get the percentage change.
What strategies can you use to solve problems involving increasing and decreasing numbers?
One strategy is to create a table or chart to organize the data and see the pattern more clearly. Another strategy is to use a formula, such as the rate of change formula, to calculate the increase or decrease. You can also use mental math or estimation to solve problems quickly.
