yellowcoconut
- 1
Hi all,
First timer here
I would like to understand how to work out how torque is involved when increasing shaft speed using DC motors.
Say if a shaft is rotating at X rpm with an applied torque of T [N.m] and a DC motor is connected through a 1:1 gearing to connect the rotating shaft and motor output shaft.
If the motor is off both shafts would spin at X rpm. However what would happen if the motor was turned?
Would it simply be to add the motor shaft speed to the current shaft speed X? Where is the torque involved in this? Is it dependent on mass of the gear rings used and distance from motor because that's the only equation for torque i can relate T = F*D
thanks
edit for missing info
First timer here
thanks
