Indefinite integration involving exponential and rational function
In summary, indefinite integration involving exponential and rational function is the process of finding the antiderivative of a mathematical expression that contains both an exponential function and a rational function. This can be done using integration techniques such as u-substitution or integration by parts. Special cases include when the exponent of the exponential function is a constant or when the rational function is a constant. This type of integration is important in various fields and is a fundamental concept in calculus.
juantheron
247
Calculation of $\displaystyle \int e^x \cdot \frac{x^3-x+2}{(x^2+1)^2}dx$
Mathematics news on Phys.org
Let \(\displaystyle y = \mathrm{e}^x \cdot \frac{x^3 - x + 2}{(x^2 + 1)^2} = f'\) for some function \(\displaystyle f\).
If we then write \(\displaystyle f = \mathrm{e}^x q\) for some function \(\displaystyle q\) and differentiate this we see that \(\displaystyle f' = \mathrm{e}^x (q + q')\). Thus we can write
\(\displaystyle \mathrm{e}^x \cdot \frac{x^3 - x + 2}{(x^2 + 1)^2} = \mathrm{e}^x (q + q') \quad \Leftrightarrow \quad \frac{x^3 - x + 2}{(x^2 + 1)^2} = q + q'\).
This could be solved directly, but I liked more to do this light differently like this:
Now I assume that function \(\displaystyle q\) can be written in form \(\displaystyle q = \frac{p}{x^2 + 1}\) using some function \(\displaystyle p\). Substituting this into the equation gives us
\(\displaystyle (x - 1)^2p + (x^2 + 1)p' = x^3 - x + 2\).
This ODE is easy to solve. For homogenous equation we obtain
\(\displaystyle p_h = C\mathrm{e}^{-x}(x^2 + 1)\)
and particular solution
\(\displaystyle p_p = x + 1\),
and thus the solution to the ODE is
\(\displaystyle p = x + 1 + C\mathrm{e}^{-x}(x^2 + 1)\).
Now we can write the functions \(\displaystyle q\) and \(\displaystyle f\), namely
\(\displaystyle q = \frac{p}{x^2 + 1} = \frac{x + 1}{x^2 + 1} + C\mathrm{e}^{-x}\)
and
\(\displaystyle f = \mathrm{e}^x q = \mathrm{e}^x \cdot \frac{x + 1}{x^2 + 1} + C\).
Hence
\(\displaystyle \int \mathrm{e}^x \cdot \frac{x^3 - x + 2}{(x^2 + 1)^2} \mathrm{d}x = \mathrm{e}^x \cdot \frac{x + 1}{x^2 + 1} + C\).
FAQ: Indefinite integration involving exponential and rational function
What is indefinite integration involving exponential and rational function?
Indefinite integration involving exponential and rational function is the process of finding the antiderivative of a mathematical expression that contains both an exponential function and a rational function. This is typically done using integration techniques such as u-substitution or integration by parts.
How do you integrate an exponential function with a rational function?
To integrate an exponential function with a rational function, you can use the substitution method by letting u equal the exponent of the exponential function. You can also use integration by parts by choosing the exponential function as your u-substitution and the rational function as your dv-substitution.
Can you give an example of indefinite integration involving exponential and rational function?
Yes, an example of indefinite integration involving exponential and rational function is ∫(5x + 2)e^(3x) dx. Using the substitution method, we let u = 3x, du = 3dx, and dx = du/3. This gives us ∫(5x + 2)e^u du/3. Simplifying, we get (5/3)∫(5x + 2)e^u du. Then, we can integrate the rational function (5x + 2) using the power rule and the exponential function e^u using the rule for integrating e^x, giving us (5/3)(5x^2/2 + 2x)e^u + C. Substituting back in u = 3x, we get the final answer of (5/3)(5x^2/2 + 2x)e^(3x) + C.
Are there any special cases when integrating exponential and rational functions?
Yes, there are special cases when integrating exponential and rational functions. For example, if the exponent of the exponential function is a constant, the integration becomes simpler as it reduces to a polynomial function. Similarly, if the rational function is a constant, integration becomes easier as it can be directly integrated using the power rule.
Why is indefinite integration involving exponential and rational function important?
Indefinite integration involving exponential and rational function is important because it allows us to solve problems in various fields such as physics, engineering, and economics. It also helps us find the area under a curve, which has many real-world applications. Moreover, it is a fundamental concept in calculus and is necessary for further studies in mathematics and science.
