Indentations in the contact surface of the clutch drum and the circula
  • Thread starter damanr
  • Tags
    problem
In summary, the contact surface of the clutch drum features indentations that are designed to enhance engagement and reduce slippage during operation. These circular indentations help improve the distribution of pressure across the clutch, leading to better performance and longevity of the component.
damanr
Hello guys, in my work we have a problem detected in the clutch drum (automatic gearbox) : indentations in the contact of the clutch drum and the circular plate, wefound that the hardness of the circular plate is higher than the clutch drum, do you guys have some propositions to solve this?
Welcome to PF.
The more details you can give, the better responses you will get. Can you link to information about this clutch mechanism? How much power is being transmitted through this gearbox? Who manufactures this clutch? Have you asked them this question?
FAQ: Indentations in the contact surface of the clutch drum and the circula
What causes indentations in the contact surface of the clutch drum?
Indentations in the contact surface of the clutch drum are typically caused by excessive wear and tear, which can result from prolonged use, high friction, or improper maintenance. These indentations can also be due to the presence of debris or contaminants that get trapped between the clutch components, causing surface damage over time.
How do indentations in the clutch drum affect vehicle performance?
Indentations in the clutch drum can lead to uneven engagement and disengagement of the clutch, resulting in jerky or inconsistent power transmission. This can cause issues such as slipping, increased wear on other clutch components, and potentially even complete clutch failure if not addressed promptly.
Can indentations in the clutch drum be repaired, or does the drum need to be replaced?
Minor indentations may be repaired through resurfacing or machining to restore a smooth contact surface. However, if the indentations are deep or extensive, it is often more cost-effective and safer to replace the clutch drum entirely to ensure optimal performance and longevity of the clutch system.
What preventive measures can be taken to avoid indentations in the clutch drum?
Regular maintenance, including timely inspection and replacement of worn components, can help prevent indentations. Ensuring that the clutch system is free of debris and contaminants, using high-quality lubricants, and avoiding excessive load or harsh driving conditions can also reduce the risk of indentations forming.
How can I identify if my clutch drum has indentations?
Signs of indentations in the clutch drum include unusual noises during clutch operation, difficulty in shifting gears, slipping or jerky clutch engagement, and visible wear patterns on the drum surface. A thorough inspection by a qualified technician can confirm the presence and extent of any indentations.
10K
124K
