Independent variables in higher derivative Lagrangian
In summary, the Lagrangian density described in this conversation is a mathematical expression that represents the dynamics of a physical system. It is constructed from the potential and its derivatives, which are considered as independent variables. Different permutations of the indices should be treated as different variables in the equation of motion, reflecting the underlying principles and assumptions of the theory. It is important to carefully consider these principles before making any conclusions.
andresB
626
374
Consider the following Lagrangian density $$\mathscr{L}=\mathbf{E}\cdot\left(\nabla^{2}\mathbf{E}\right)$$
where $$E_{i}=\partial_{i}\phi\;(i=x,y,z
In th
is case the potential and its 3rd derivatives are the independent variables. Acording to Barut's classical theory of fields book, for the above system the Euler-Lagrange equation contains two terms
$$\partial_{i}\frac{\mathscr{\partial L}}{\partial(\partial_{i}\phi)}$$ and $$\partial_{ijk}\frac{\mathscr{\partial L}}{\partial(\partial_{ijk}\phi)}.$$The issue is the following: are different permutation of the indices to be considered the same variable or different variables?, for example, Asuming a well-behaved function we have that $$\partial_{xxy}\phi=\partial_{xyx}\phi=\partial_{yxx}\phi,$$
but should the term $$\partial_{xxy}\frac{\mathscr{\partial L}}{\partial(\partial_{xxy}\phi)}$$ appear once or three times in the equation of motion?
it is important to consider the underlying principles and assumptions of the theory before making any conclusions. In this case, the Lagrangian density is a mathematical expression that describes the dynamics of a physical system. It is constructed from the potential and its derivatives, which are considered as independent variables.
In the context of this Lagrangian density, the potential and its third derivatives are indeed considered as independent variables. This means that different permutations of the indices should be treated as different variables. Therefore, the term $$\partial_{xxy}\frac{\mathscr{\partial L}}{\partial(\partial_{xxy}\phi)}$$ should appear three times in the equation of motion.
This may seem counterintuitive, but it is important to remember that the Lagrangian density is a mathematical construct and not a physical quantity. It is a tool used to describe the behavior of a physical system and is based on certain assumptions and principles. In this case, the assumption is that the potential and its third derivatives are independent variables, and this should be reflected in the equation of motion.
In conclusion, different permutations of the indices should be considered as different variables in the equation of motion for this Lagrangian density. It is important to carefully consider the underlying assumptions and principles of a theory before making any conclusions or interpretations.
Related to Independent variables in higher derivative Lagrangian
What is an independent variable in a higher derivative Lagrangian?
An independent variable in a higher derivative Lagrangian is a variable that is not explicitly dependent on any other variables in the equation. It is the variable that is varied or manipulated in order to observe the effects on the dependent variables.
Why are independent variables important in higher derivative Lagrangian?
Independent variables are important in higher derivative Lagrangian because they allow for the study and understanding of the relationships between different variables in a system. By manipulating the independent variable, we can observe how the dependent variables change and gain insight into the behavior of the system.
What types of independent variables can be used in higher derivative Lagrangian?
There are various types of independent variables that can be used in higher derivative Lagrangian, including physical quantities such as time, position, and velocity, as well as abstract variables like temperature, pressure, and energy.
How do independent variables affect the Lagrangian equations?
The independent variables are used to define the terms in the Lagrangian equations. By manipulating the independent variables, we can change the terms in the equations and observe how this affects the overall behavior of the system.
Can there be more than one independent variable in a higher derivative Lagrangian?
Yes, there can be more than one independent variable in a higher derivative Lagrangian. This is often the case in complex systems where multiple variables are involved in determining the behavior of the system.
  • Classical Physics
  • Classical Physics
  • Classical Physics
  • Calculus
