Will Reflected Light Be Eliminated by Interference in These Thin Film Scenarios?
In summary: There is a phase reversal between water and glass, but the wavelength is not in phase because the PLD for glass is (1/2)λ while water has a PLD of (1). So the wavelength is out of phase.
blue_lilly
36
The diagram shows light incident from above on a film of thickness d. Each of the three materials in the figure can be chosen to be air, with index of refraction n=1.00, water, with index n=1.33, or glass, with index n=1.50. Under which of the following conditions will the reflected light be completely or nearly eliminated by interference?
(lambda2 refers to the wavelength of the light inside the thin film.)
(Note: In the case that d<<lambda2, you can assume the thickness is so small that the travel distance in material 2 has negligible affect on the phase of the wave. Treat this as if the two interfaces are almost right on top of each other.)
http://s3.amazonaws.com/answer-board-image/390a9f5e-a2a9-4fbe-a6f6-c33689d8251c.gif
1) T/F d=lambda2/4, material 1 is air, 2 is water, 3 is glass.
2) T/F d=lambda2/2, material 1 is air, 2 is water, 3 is glass.
3) T/F d=lambda2/4, material 1 is glass, 2 is air, 3 is glass.
4) T/F d=lambda2/4, material 1 is water, 2 is glass, 3 is air.
5) T/F d<<lambda2, material 1 is water, 2 is glass, 3 is air.
2*n*d*sinθ = (m-(1/2))*λ
m=integer
λ=wavelength
n=index of refraction = speed of light in vacuum/speed of light in medium
d= thickness
We are looking for places where the refracted light is eliminated by interference, so we are looking for destructive interference.
Destructive if Path-length Difference(PLD) 2nd= (m + (1/2))λ when the sources are exactly in phase.
Destructive if Path-length Difference(PLD) 2nd = mλ when the sources are exactly out of phase.
There are phase reversals when it is reflecting of a higher n.
1) d=lambda2/4, material 1 is air(n=1.00), 2 is water, 3 is glass.
True because
There would be 2 phase reversals [1 between air and water and the other between water and glass] So the wavelength would be exactly in phase which means it needs to have PLD of (1/2)λ
d=2λ/4
(2λ/4) = (1/2)λ
(2/4)λ= (1/2)λ
(1/2)λ= (1/2)λ
2) d=lambda2/2, material 1 is air(n=1.00), 2 is water(n=1.33), 3 is glass(n=1.50).
False because
d=2λ/2
2λ/2 = (1/2)λ
(2/2)λ = (1/2)λ​
3) d=lambda2/4, material 1 is glass(n=1.50), 2 is air(n=1.00), 3 is glass(n=1.50).
True because
There would be 2 phase reversals [1 between air and glass and the other between air and glass] So the wavelength would be exactly in phase which means it needs to have PLD of (1/2)λ.
d=2λ/4
(2λ/4) = (1/2)λ
(2/4)λ= (1/2)λ
(1/2)λ= (1/2)λ
4) d=lambda2/4, material 1 is water(n=1.33), 2 is glass(n=1.50), 3 is air(n=1.00).
True because
There would be 2 phase reversals [1 between air and water and the other between the water and glass] So the wavelength would be exactly in phase which means it needs to have PLD of (1/2)λ.
d=2λ/4
(2λ/4) = (1/2)λ
(2/4)λ= (1/2)λ
(1/2)λ= (1/2)λ
5) d<<lambda2, material 1 is water(n=1.33), 2 is glass(n=1.50), 3 is air(n=1.00).
False because
d<<lambda2
λ2= (1/2)λ
I thought i was doing right but the answer is incorrect.
Any help would be greatly appreciated.
Hello.
You are not getting the number of phase reversals correct for some of the cases. How do you decide if a phase reversal occurs?
TSny said:
Hello.
A phase reversal happens when the n it is "hitting" is larger then what the "n" was before.
1) d=lambda2/4, material 1 is air(n=1.00), 2 is water(n=1.3), 3 is glass(n=1.5).
So for this one the wave is traveling in air and then it hits water, which has a higher "n" value. this means that part of the wave is reflected back and part continues through the water. The wave traveling in the water "hits" the glass and glass has a higher "n" value then water so part of the wave reflects back and some continues through the object.
I thought this was how you are supposed to tell. Is it incorrect?
Yes. You got this one right. But some of the other cases are incorrect. For example, check case(3).
Your attempt at a solution is on the right track, but there are a few errors in your reasoning. First, let's clarify some concepts:
1. Path-length difference (PLD) refers to the difference in distance traveled by two waves. This can be calculated by taking the difference in the path lengths of the two waves, which is equal to the thickness of the film (d). This is important because the PLD determines whether the waves are in or out of phase and therefore whether we have constructive or destructive interference.
2. Phase refers to the position of a wave in its cycle. When two waves are in phase, their crests and troughs line up and they reinforce each other. When they are out of phase, their crests and troughs are misaligned and they cancel each other out.
Now, let's go through each statement and see where things went wrong:
1) T/F d=lambda2/4, material 1 is air(n=1.00), 2 is water, 3 is glass.
True because
d=2λ/4
(2λ/4) = (1/2)λ
(2/4)λ= (1/2)λ
(1/2)λ= (1/2)λ
Your reasoning here is mostly correct, but there are a few small errors. First, the PLD for destructive interference is (1/2)λ, not (1/4)λ. This means that the thickness of the film (d) should be equal to (1/2)λ, not (1/4)λ. So the correct statement would be "d=lambda2/2". Also, your calculation of d=2λ/4 is incorrect. It should be d=(1/2)λ. Finally, your last line "(1/2)λ= (1/2)λ" is unnecessary and doesn't add any new information.
2) T/F d=lambda2/2, material 1 is air(n=1.00), 2 is water(n=1.33), 3 is glass(n=1.50).
False because
Related to Will Reflected Light Be Eliminated by Interference in These Thin Film Scenarios?
1. What is the index of refraction of a thin film?
The index of refraction of a thin film refers to the measure of how much light is bent as it passes through the film. It is determined by the ratio of the speed of light in a vacuum to the speed of light in the thin film.
2. How is the index of refraction of a thin film measured?
The index of refraction of a thin film can be measured using various techniques such as ellipsometry, interferometry, or spectroscopic methods. These methods involve measuring the change in polarization, phase, or wavelength of light as it passes through the thin film.
3. What factors affect the index of refraction of a thin film?
The index of refraction of a thin film can be affected by several factors including the composition and thickness of the film, the wavelength of light, and the angle of incidence. It can also be influenced by external factors such as temperature, pressure, and humidity.
4. What is the importance of the index of refraction of thin films?
The index of refraction of thin films is important in various fields such as optics, electronics, and materials science. It is used to study the optical properties of materials, design and manufacture optical devices, and control the reflectance and transmittance of light in thin film coatings.
5. How can the index of refraction of a thin film be manipulated?
The index of refraction of a thin film can be manipulated by changing the composition and thickness of the film, as well as the angle of incidence and the wavelength of light. It can also be altered by applying external stimuli such as electric or magnetic fields, or by controlling the growth conditions during the manufacturing process.
