Induced charge distribution on two different radius sphere
In summary, two insulated metal spheres of equal sizes with equal positive charges are brought close to each other without touching. The smaller sphere has a higher charge density and more intense electric field. The larger sphere may also experience charge redistribution or become a dipole if the smaller sphere has a much higher charge density.
jemerlia
28
Two insulated metal spheres of equal sizes are given equal positive
charges. The two spheres are brought very close to each other without
touching. Draw the new charge distribution on the spheres if one sphere
is much larger than the other.
[Coulomb's law] - qualitative result only
The two spheres have different radii. Initially the charge on both spheres will be evenly distributed over their surface. The smaller sphere has the greater charge density and the more intense electic field. When the two are brought close together please confirm the charge distribution is as shown below. Perhaps there will also be separation of charge on the larger sphere. The smaller sphere will experience some charge redistribution.
N.B. The inside of the spheres are shown filled with "o" characters:
....o
...+.ooooo......+
...+.oooooooo......o.+
...+.ooooooooooo.-...+.ooo.+
...+.ooooooooooooo.-...oooooo
...+.oooooooooo.-...ooo.+
...ooooo......+
...o
I guess it's possible the larger sphere could become a dipole if the smaller sphere was small enough and hence had a much higher charge density and hence electric field.
Is this correct?
The larger sphere will experience a redistribution of charge, with more of the positive charges being pushed towards the side facing the smaller sphere. This is due to the repulsive force between the like charges on the two spheres. The smaller sphere will also experience a redistribution of charge, with some of the positive charges being pulled towards the larger sphere. This is due to the attractive force between the opposite charges on the two spheres. Overall, the charge distribution on the spheres will not be symmetrical, with more charge on the side facing the other sphere. This is known as induced charge distribution and is a result of the interaction between the two spheres.
Related to Induced charge distribution on two different radius sphere
1. What is induced charge distribution on two different radius spheres?
Induced charge distribution on two different radius spheres is a phenomenon that occurs when two charged spheres of different sizes are placed in close proximity to each other. The charges on the spheres will redistribute in order to minimize the electrostatic potential energy of the system.
2. How does the charge distribution change when the two spheres are brought closer together?
When the two spheres are brought closer together, the charges on the smaller sphere will redistribute towards the larger sphere, resulting in a larger concentration of charge on the side facing the larger sphere. The larger sphere will also experience a redistribution of charge, but to a lesser extent.
3. What factors affect the induced charge distribution on two different radius spheres?
The induced charge distribution on two different radius spheres is affected by several factors, including the distance between the spheres, the size and magnitude of the charges on the spheres, and the dielectric constant of the medium between the spheres.
4. Can the induced charge distribution be calculated mathematically?
Yes, the induced charge distribution on two different radius spheres can be calculated using the method of images or the method of images in conjunction with Gauss's Law. These methods involve solving for the electric potential and electric field at each point on the surface of the spheres.
5. What are some real-world applications of induced charge distribution on two different radius spheres?
Induced charge distribution on two different radius spheres has various applications in physics and engineering, such as in capacitors, electrostatic precipitators, and Van de Graaff generators. It also plays a role in the behavior of charged particles in particle accelerators and the interaction between charged particles in space.
