Induced EMF in metal loop near RC circuit
In summary, the problem involves a rectangular metal loop with 0.050 ohms resistance placed next to one wire of an RC circuit. The capacitor is charged to 20 V and the switch is closed at t = 0s. The task is to calculate the EMF (in V) induced in the metal loop at t = 5.0 μs, assuming that only the circuit wire next to the loop is close enough to produce a significant magnetic field. The RC circuit discharging equation gives the current as a function of time, but in order to calculate the EMF, the time variable needs to be kept in the equations. Integrating the current and using the magnetic flux through the loop at that current, the EMF can
neemer
(Challenge Problem 80, Ch33) A rectangular metal loop with 0.050 ohms resistance is placed next to one wire of the RC circuit shown in the below figure. The capacitor is charged to 20 V with the polarity shown, then the switch is closed at t = 0s.
[url=http://postimg.org/image/bjo7lwzh5/][PLAIN]http://s4.postimg.org/bjo7lwzh5/P33_80_Figure.jpg[/url][/PLAIN]
What EMF (in V) is induced in the metal loop at t = 5.0 μs? (Assume that only the circuit wire next to the loop is close enough to produce a significant magnetic field.)
I=(V0/R)e^(-t/RC)
dø=B . dA ?
ε = dø/dt
The RC circuit discharging equation gives me the current as a function of time. I=(V0/R)e^(-t/RC)
First I tried just solving this for t= 5.0μs and got I = 6.065. Then I integrated to solve for the magnetic flux through the loop at that current and got 8.5x10^-8 T. This is where I am stuck now since I can't use ε = dø/dt to calculate the EMF with only ø and I can't differentiate this with respect to time with no time variable.
So now I'm thinking that I need to keep the time variable in my equations instead of just solving for a specific time at the beginning so i can end up with dø/dt. I calculated dI/dt and tried to use this in my integral instead of I, only now I have no idea how to solve this integral with only first year calculus. Now I'm thinking that I may have missed/overlooked something that helps to simplify this problem?
[PLAIN]http://postimg.org/image/bjo7lwzh5/ [/PLAIN]
I=(V0/R)e^(-t/RC)
dø=B . dA ?
ε = dø/dt
Note that magnetic field strength is given in T (Tesla), while the flux is in Tm2, or Wb (Webers).
You're thinking along the right path.
When you integrate to find the flux at some instant of time, the time variable can be treated as a constant. Easier: Just leave the current expressed as I(t) in your symbolic integration over the loop area. You can plug in the actual function of time for I(t) after the dust from the integration settles.
While the intent of the problem may be to determine the emf generated by the circuit wire's B field as though the loop resistance were infinite, this is not the case here.
The finite loop current generates its own B field which represents a counter emf around the loop. So there are two sources of emf around the loop: that generated by the circuit wire's B field and the counter-emf generated by the loop current.
To compute the total emf in the loop requires knowing the self-inductance of the loop.
To make matters more complex still, the circuit wire current is not simply what it would be in the absence of the loop. So there is also mutual inductance to be considered. Fortunately, not enough information is given to extend the problem to that level.
BTW consider the circuit wire length to be infinite.
Thanks for the help. Got the answer when I integrated this time.
Did you include the loop resistance in your computations?
No not in those calculations but the next question was to calculate the induced current in the loop so I used it then. Was I supposed to use it in the first part too?
Well, as I said, I suspect the answer is no, because in an introductory course the only B field they want you to consider is the externally applied field (thhe one generated by the circuit wire). So you don't use R of the loop until you compute the current which will be a very simple procedure.
But, as I said, the real picture is that the loop current generates its own B field which tends to counter the wire B field and generates its own emf ("back emf"), and the net emf in the loop is the algebraic sum of the two separate emf's. However, in order to compute the back emf numerically you'd need the self-inductance of the loop which is not at all easy to compute. So that's ususally encountered in an advanced e-m course. Either that or the self-inductance is given in the problem (there are websites that can compute it too). And, as I further said, the picture is even more complicated since the circuit wire current gets modified by the loop current via something called 'mutual inductance'.
Bottom line: reality is often more complicated than can be ascertained by a simple formula! So just consider this a sample of what lies ahead if you decide to pursue an advanced e-m course. Meanwhile, what you did was what the problem intended, I'm sure.
Related to Induced EMF in metal loop near RC circuit
1. What is induced EMF in a metal loop?
Induced EMF, also known as induced electromotive force, is a phenomenon where a changing magnetic field creates an electric current in a conductor. In the case of a metal loop near an RC circuit, the changing magnetic field is created by the circuit's resistor and capacitor.
2. How does an RC circuit induce EMF in a nearby metal loop?
In an RC circuit, the resistor and capacitor work together to create a changing magnetic field. When this field intersects with a nearby metal loop, it induces an electric current in the loop, creating an induced EMF.
3. What factors affect the magnitude of induced EMF in a metal loop near an RC circuit?
The magnitude of induced EMF is affected by several factors, including the strength and frequency of the changing magnetic field, the size and shape of the metal loop, and the distance between the loop and the RC circuit.
4. How is induced EMF used in practical applications?
Induced EMF has a variety of practical applications, including in generators and transformers. It is also used in wireless charging technologies and some types of electric motors.
5. Can induced EMF cause any harm?
In most cases, induced EMF does not pose any harm. However, in some situations, such as near power lines or large generators, it can cause interference with electronic devices or induce currents in the human body. It is important to follow safety guidelines and regulations in these situations.
