Inducing electricity w/ moving piece of metal, static magnet
In summary, the principle behind producing electricity by moving a piece of metal over a magnet is the basis for electric generators. This process involves changing the magnetic field that the metal experiences, which generates a current and voltage. This is done on a large scale and can also be seen on a smaller scale, such as the generator light on a bicycle. However, if both the copper coil and magnet are static, no power is generated. To generate power, the magnet can be made to follow the metal, creating a changing magnetic field that induces electrical currents. This concept is known as Faraday's law and can be demonstrated through various experiments and devices, such as the compass experiment and a small DC motor or generator.
kallesmajs
Hi!
I'm curious to know, whether it is possible to produce electricity by moving a piece of metal over a magnet (i.e a immobile magnet and a moving piece of metal close to the magnet), and how this would be done in practice.
Likes ISamson
This is the principle behind an electric generator. The change in the magnetic field that the conductor (metal) experiences produces an internal EMF (electromotive force), basically a voltage, that generates a current that in addition, has electrical power. It is done basically universally, on a very large scale, and is also done on a much smaller scale, like the generator light for a bicycle where the tire turns the turbine to produce the electricity that lights the light.
Likes ISamson
Thank you very much for your quick answer!
I assume, the same would not work, if for example we had a static(immobile) 'device' made up of a copper coil and a permanent magnet, whereas the moving conductor(metal) is not the one that we want to produce the electricity, but rather the copper coil?
If the copper wire and magnet are both standing still, you don't generate any power.
Right, that is what i thought. But if we were to make the magnet follow the metal (imagine a closed box with a string from end to end in the box, and the string goes through a now mobile magnet. Around the string and magnet goes a coil, so that when we move the metal the magnet will follow the metal because its on a string and it will move inside a coil as well) it should generate right?
This is wrong. Inductive pickup sensors work in this exact manner. While it is not generally the way we generate power it is a very practical sensor.
## \\ ## Editing: In more detail, I see where the OP's question could be interpreted this way. They have another conductor moving nearby. This generates currents and a weak changing magnetic field that can get picked up by a stationary coil. I did not interpret the OP's question in this manner though=from what I could tell the OP was interesting in generating electrical power-in a reasonably efficient manner. ## \\ ## In addition, if the moving material is ferromagnetic, e.g. iron, it could then get sufficient magnetization inside of it to produce a magnetic field of its own, but I believe this is beyond the scope of the OP's question.
Presumably the metal in this case is e.g. iron, so that there is an attractive force between the iron and the magnet. When the magnet moves and changes position relative to a copper coil, yes, it should generate electricity. Suggestion is to google "Faraday's law" for additional information on how a changing magnetic field can generate electrical currents.
Videos like this might be useful.
Likes Charles Link
@Dadface Very interesting. Thank you. Also of interest is copper actually is very much non-magnetic (I believe only slightly diamagnetic) in its response to a static magnetic field. A change in the magnetic field can however induce large currents to create sizable magnetic fields that act to repel the magnet and keep it from falling quickly. I was still very surprised to see the effect is as strong as it is. Very interesting.
There is a process for learning these concepts! Typically it involves the old magnet and iron filings. This helps show the shape of the magnetic field, and illustrates magnetic flux lines ( noting that lines of flux is really more of an analogy than reality)... anyway, we can now visualize the magnetic field. We "play with other magnets, magnetic items, and see how the field reacts.
Next we often see the compass type experiment, where we pulse current through a wire near a compass and see the compass needle deflect, demonstrating that current in the wire creates a magnetic field ( Amperes law) AND that the magnetic field can apply a force on the compass needle. By arranging the compass and wire differently we can change the type of deflection (reaction - magnitude and direction) of the needle. Additionally it needs to be noted that the same force ( well equal an opposite) is applied the the wire - according to Newton's 3rd.
As our physics education continues - we perhaps have a small coil and magnet, with the coil connected to a galvanometer ( very sensitive current meter) - we see that we can create a current by passing the magnet through, or by the coils.
We may build a small dc motor / generator, with with we see, and demonstrate a machine, utilizing these concepts to turn electrical current into mechanical motion ( motor) or mechanical motion into electrical current (generator) - etc.
In the end we see or know that a conductor in a varying magnetic field will have a current induced in it, and visa-versa. The filed can vary in essentially any manner, the magnet and conductor moving relative to one another, the mag field could be created by another electrical circuit (conductor or coil) and be expanding or collapsing as the current is changing in that conductor, or the magnetic field could be affected by the "movement" of a magnetic material, or even another conductor in the area. But the core concept is that the relationship of the field and the conductor must be changing.
Likes Charles Link
Related to Inducing electricity w/ moving piece of metal, static magnet
What is electromagnetic induction?
Electromagnetic induction is the process of using a moving piece of metal, such as a wire, near a static magnet to generate an electric current. This is accomplished by the movement of the metal through the magnetic field created by the magnet, which causes a flow of electrons and thus produces electricity.
How does a moving piece of metal induce electricity?
When a conductor, such as a piece of metal, moves through a magnetic field, the magnetic field exerts a force on the electrons in the conductor. This force causes the electrons to move, creating an electric current in the wire. This process is known as electromagnetic induction.
What are some real-life applications of electromagnetic induction?
There are many practical applications of electromagnetic induction, including generators, transformers, and electric motors. Generators use electromagnetic induction to convert mechanical energy into electrical energy, while transformers use it to change the voltage of an alternating current. Electric motors also use electromagnetic induction to convert electrical energy into mechanical energy.
Can electromagnetic induction be used to produce unlimited amounts of electricity?
No, electromagnetic induction can only produce electricity as long as the metal conductor is moving through the magnetic field. Once the motion stops, the flow of electrons and the production of electricity also stops.
What are some factors that affect the amount of electricity produced through electromagnetic induction?
Several factors can affect the amount of electricity produced through electromagnetic induction, including the strength of the magnetic field, the speed and direction of the metal conductor, and the properties of the conductor itself, such as its length, thickness, and material composition.
  • Classical Physics
  • Other Physics Topics
  • Electrical Engineering
