Inducing Voltage in a Transformer: How Does It Work?
A changing current in a transformer's primary winding creates a changing magnetic field that induces voltage in the secondary winding, even when the secondary is unloaded and has no current. In real-world transformers, the secondary winding's capacitance allows for charging and discharging during each AC half-cycle, resulting in a small amount of primary current known as magnetizing current. This magnetizing current behaves like an inductor, demonstrating that transformers can be viewed as inductors with additional windings. When a resistive load is connected to the secondary, in-phase currents flow in both the primary and secondary, indicating real energy transfer. Thus, the induced voltage in the secondary occurs independently of any load current.
Elquery
TL;DR Summary
A changing current in a transformer primary produces a changing magnetic field, which induces a voltage in the secondary, but if no circuits are closed on the secondary, there's no current in the primary. How is there measurable voltage on the secondary?
A changing current in a transformer primary produces a changing magnetic field, which induces a voltage in the secondary (correct?), but if no circuits are closed on the secondary, there's no current in the secondary (and therefore primary as well). So how is this voltage induced?
If the secondary is unloaded, the impedance is infinite in the ideal case, so that a secondary voltage & zero current occur.
In real world transformers, the secondary winding has a capacitance. This capacitance charges & discharges every ac half cycle. The secondary current is not zero, due to charging & discharge action.
Likes phinds and berkeman
There is always some (often small) amount of primary current in a transformer. We call this the magnetizing current and it is essentially the same as if the transformer primary was a simple inductor. In fact most physics classes are taught with "coupled inductors" as opposed to "transformers". It is important to understand that a transformer is just an inductor with extra windings (the secondaries). You can see more of the details in this older post, although you may find it a bit complex. The point is that every transformer model should have an large inductor (the magnetizing inductance) shunting one of the windings. This models the impact of the magnetic core on the windings, this is the inductor that is coupled to the other windings.
Likes Charles Link, Babadag, tech99 and 2 others
The voltage in the secondary is induced independent of any secondary current to a load.
The primary is an inductor, so a reactive current flows that magnetises the core. That reactive current is in quadrature with the primary voltage and represents idle energy circulating in the supply and primary winding, not real power.
If a real resistive load is connected to the secondary, in-phase currents will flow in the secondary and the primary. Those in-phase currents represents real energy being transferred from the supply to the secondary load.
Likes Babadag, cnh1995 and berkeman
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
