Inductance and Charge Redistribution
In summary: I'm not sure what point B is supposed to be!In summary, Kirchhoff's loop rule has to do with adding up changes in potential around a closed loop (so there are actually two oddities with the 'loop law' in your relevant equations: ##\frac{kq}{r}## is a potential and not a potential difference :wink:); though I guess you could consider a closed loop to infinity and back in which case your construction is nearly correct. However, if we ignore the mutual capacitance between A and B, we end up with two capacitors "connected to infinity".
  • #36
So
My textbook's solution says that :
angular frequency of the LC oscillation is w=sqrt( 2*pi*##E_0##*R*L)
And that required time is one fourth of time period
Can you explain this please @rude man @archaic
  • #37
Instead of my other suggestion, you should take ##Q(t)=cQ_A(t)##.
$$\frac{kQ_A(t)}{r} - \frac{k(Q_0-Q_A(t))}{r} = L\frac{di}{dt}=L\frac{d^2}{dt^2}\left(cQ_A(t)\right)\\
\implies\frac{k}{r}\left(2Q_A(t)-Q_0\right)=cL\frac{d^2Q_A(t)}{dt^2}$$
Take ##f(t)=2Q_A(t)-Q_0##, this gives you ##f''(t)=2Q_A''(t)##, thus
$$\frac{k}{r}f(t)=\frac{cL}{2}\frac{d^2f(t)}{dt^2}$$
Likes Delta2
  • #38
Ayesha02 said:
So
Can you please explain this @archaic
  • #39
You have$$\frac{k}{r}f(t)=\frac{cL}{2}\frac{d^2f(t)}{dt^2}$$where ##f(t)=2Q_A(t)-Q_0##. You want to find the time at which ##Q_A(t)=\frac{Q_0}{2}##.
Start by solving the differential equation, and remember what I said about ##c##!
  • #40
Hint: what are ##Q_A(0)## and ##i(0)##?
  • #41
I am not sure I agree with all the posts here, but I believe the final equation first presented at post #37 should have a minus sign in front. coming from the fact that the voltage in an inductor is ##V=-L\frac{dI}{dt}##.
Also because the "circuit" is not so local the current will vary spatially across the two ends of the inductor, so i believe we should explicitly state as a vital assumption that the current does not vary spatially but only temporally.
  • #42
I have multiplied by ##c## for lack of knowledge abour the sign, and yes, it turned out to be ##-1##!
Likes Delta2
  • #43
I think the ##\frac{kQ_A(t)}{r} - \frac{k(Q_0-Q_A(t))}{r} = L\frac{di}{dt}## is okay because that's just passive sign convention, OP just needs to be careful when substituting in ##i = -\frac{dQ_A}{dt} = \frac{dQ_B}{dt}## since you should get a negative sign out the front. From then on, it's just a mass on the end of a spring problem :wink:.
Likes Delta2
  • #44
Oh, a sign convention? So we don't care at all about the actual sign by analyzing the charge functions?
  • #45
You can work it all out logically, but it's often quicker to do anything circuit related with the so-called passive sign convention
Essentially, if the reference direction for the voltage is in the opposite direction to the reference direction for current, then the formulae for passive components hold without negative signs, i.e. ##v=ir##, ##i = c\frac{dv}{dt}##, ##v = l\frac{di}{dt}##. A consequence is that passive components have positive power. If you define the reference directions the other way around (the so-called active sign convention, which I hear isn't usually done in electrical engineering), then all of those defining equations have negative signs in them.
It just means that here we can define the reference voltage direction as from B to A (i.e. V(A) - V(B)) and the reference current direction from A to B, and not worry about getting the signs wrong.
Likes Delta2
  • #46
Thanks for explaining the sign convention used in circuits at post #45 but one more thing I want to ask, why do you take current to be ##I=-\frac{dQ_A}{dt}=\frac{dQ_B}{dt} ## and not ##I=\frac{dQ_A}{dt}=-\frac{dQ_B}{dt}##
  • #47
I defined the reference direction of ##i## to be in the direction from A to B, so positive current results in B gaining charge and A losing charge.
Sorry for not making that clear; I have the feeling that we defined everything in exactly the exact opposite way!
Likes Delta2
  • #48
@etotheipi
Can you explain how do i solve the equation after substituting ,##i## ?
  • #49
@Ayesha02 Try what @archaic suggested (I have substituted for ##c## for clarity):
archaic said:
Instead of my other suggestion, you should take ##Q(t)=-Q_A(t)##.
$$\frac{kQ_A(t)}{r} - \frac{k(Q_0-Q_A(t))}{r} = L\frac{di}{dt}=L\frac{d^2}{dt^2}\left(-Q_A(t)\right)\\
\implies\frac{k}{r}\left(2Q_A(t)-Q_0\right)=-L\frac{d^2Q_A(t)}{dt^2}$$
$$\frac{k}{r}f(t)=\frac{-L}{2}\frac{d^2f(t)}{dt^2}$$
That last equation is the same as ##\frac{-2k}{Lr} f(t) = f''(t)##. That reminds me of another physical phenomenon, i.e. a mass on a spring which behaves like ##a _x= -\omega^2 x##. Can you then work out the solution of the differential equation?
Likes Delta2 and archaic
  • #50
@Ayesha02 if you haven't solved differential equations before, then suppose that ##f (t)=A\cos (\omega t-B)## and use the initial conditions I hinted at in a previous post to find the unknowns.
Likes etotheipi
  • #51
ohh thanks buddy!
Likes archaic
  • #52
@Ayesha02 can you please tell me from which book is this exercise , for me at least it represents a fine blending of electrostatics with circuit theory ,and I just want to know from which book it is.
Likes etotheipi
  • #53
I agree, it's quite a fun question. Am interested also!
  • #54
Are you guys from India, by any chance?
We have a real tough exam here that we've to appear, and this is one of the questions from our preparatory material.
Likes archaic
  • #55
Probably from Irodov's problems in general physics or a JEE problems textbook.
  • #56
Ayesha02 said:
So
You have written ##\epsilon_0 ## a wrong way.
I further think you copied wrong because that answer is dimensionally incorrect.
How about you left out a "1/"?
That answer would be correct.
Likes Delta2 and etotheipi
  • #57
yeah i got that...i missed the reciprocal
although, could you help me understand the solution theyve given?
  • #58
The charge oscillates back and forth between the two spheres at that radian frequency.
The only way you're going to get the answer is by solving the differential equation. There are a number of ways to do that, for example the way a previous poster suggesting a solution of the form ## cos(\omega t - \phi) ##, ##\phi ## a constant.
  • #59
Ohh finally!
understood:)
  • #60
What have you got up until now from solving the differential equation?
  • #61
Additional comment: it is an interesting probem because it makes concrete the nexus between 'potential' of physics and 'voltage' of electrical engineering.
Likes Delta2
  • #62
Yeah, there are a few different ways you could think about it. Either a closed loop to infinity and back, in which case you can treat the potential as the potential difference between the sphere and infinity: ##\frac{kQ_A}{r} - L\frac{di}{dt} - \frac{kQ_B}{r}##. Or you could think about it in the sense of two potentials ##\frac{kQ_A}{r}## and ##\frac{kQ_B}{r}## and a potential difference between them...
Can blur the lines a little but but usually the distinction is that to discuss potential we have a fixed reference, so it means being extra careful when discussing the potential relative to another arbitrary point (really differences) as opposed to a potential relative to the fixed reference.
  • #63
Guys I have a lot of these kinda problems just follow me and stay tuned so that we have more of these discussions.
The most recent one i have put up goes by the title- 'Hard Momentum Conservation'
See u there:)
  • #64
Ayesha02 said:
See u there:)
Sorry, I had to:
  • Haha
Likes rude man and Ayesha02
  • #65
See u there:)
@etotheipi I need u there my man:)
  • #66
etotheipi said:
Sorry, I had to:
:smile: :smile:
We badly need some humor on this site. We all love physics but we need to take even it a bit more lightly now and then. Thank you! (Of course this song always reminds me of 'Dr. Strangelove' too.)
  • Love
Likes BvU and etotheipi
  • #67
See u there:)
We helpers love to help! Really! Forces us to review also, often; so in a sense you're a helper too! And all of us love physics all the time!
  • #68
rude man said:
:smile: :smile:
Especially now that cabin fever has fully set in :wink:
