Inductance and RL circuits help
Finally, add the current in L and the voltage in L to get the switch current. In summary, to find the current in the inductor at t = 0.224 s, you need to find the voltage across the LR circuit first and then use the relevant formula to calculate the current in the inductor. Finally, the switch current can be obtained by adding the current in the inductor and the voltage in the LR circuit.
christianerik
If the switch is closed at t = 0, find the
current in the inductor at t = 0.224 s. Answer
in units of A.
Find the current in the switch at that same
time.
I know that i must use i = V/R(1 - e^-t/L/R) but can't seem to get the right answer.
Any help is appreciated...5 ohms
-------------^^^^^^^------I
I.......I
I...10 ohms...1.4 H...I
I------^^^^^^^^---&&&&--I
I.......I
I...S...30 V...5 ohms.I
I-------/..---I I----^^^^^--I
What am I doing wrong?
i = V/R(1 - e^-t/L/R + V/5 = (30 - V)/5
(V/10)( 1 - e^-(0.224*10/1.4) + V/5 = -V/5 + 6
0.1V(0.798)+0.4V = 6
(0.4+0.0798)V = 6
V = 6/0.4798 = 12.5 v
The inductor current at t = 0.224 s
i = (12.5/10)[ 1 - e^-(0.224(10/1.4) ]
i = 0.9976 A
The switch current:
Is = i + V/5 = 0.9976 + 12.5/5 = 3.497 A
First of all you have to find the voltage across LR circuit.
At t=0 L acts like a conductor. Find the total resistance and current in the circuit. Hence find the voltage across LR circuit.Then use relevant formula to find the current in L.
It seems like you have the right approach, but your calculations may be a bit off. First, let's look at the equation you are using:
This equation assumes that the switch is closed at t=0, so there is no need to add V/5 to the equation. Also, the equation should be:
i = V/R(1 - e^-t/R/L)
Notice that the order of R and L are switched compared to what you wrote. This is important because the time constant for an RL circuit is L/R, not R/L. So let's rewrite the equation using the correct order:
Now let's plug in the values given in the problem:
i = (30/10)(1 - e^-(0.224/5))
i = 3(1 - e^-0.0448)
i = 3(1 - 0.955)
i = 3(0.045)
i = 0.135 A
So the current in the inductor at t = 0.224 s is 0.135 A.
To find the current in the switch, we simply add V/R to the equation:
Is = i + V/R = 0.135 + 30/10 = 3.135 A
So the current in the switch at t = 0.224 s is 3.135 A.
FAQ: Inductance and RL circuits help
What is inductance?
Inductance is a property of an electrical circuit that describes its ability to store energy in the form of a magnetic field. It is measured in units of Henry (H) and is represented by the symbol L.
How does inductance affect an RL circuit?
In an RL (resistor-inductor) circuit, inductance causes a time delay in the flow of current due to the energy stored in the magnetic field. This results in a lag between the voltage and current in the circuit, known as the phase difference.
How is inductance calculated in an RL circuit?
The inductance of an RL circuit can be calculated using the formula L = Φ/I, where Φ is the magnetic flux and I is the current. It can also be calculated using the formula L = -V/L(dI/dt), where V is the voltage and dI/dt is the rate of change of current over time.
What is the role of inductance in AC circuits?
Inductance plays a crucial role in AC (alternating current) circuits as it causes a phase shift between the voltage and current. This allows for AC devices such as transformers and motors to function properly.
How can inductance be controlled in a circuit?
The inductance of a circuit can be controlled by changing the number of turns in the inductor coil, the material of the core, and the shape and size of the coil. It can also be controlled by adding capacitors in parallel to the inductor, which creates a resonant circuit and reduces the effective inductance.
