Inductance of Square Coil Antenna on PCB
In summary, the individuals are discussing the design of an Inductive Square Antenna Coil and the matching circuit. The individual is trying to reduce the impedance of the antenna, which they believe is too high. They are also discussing the use of a matching network and determining the appropriate values for the shunt capacitor.
amanno
Hey guys, I am trying to design an Inductive Square Antenna Coil that will be milled onto my PCB. I am slightly confused when it comes to the matching circuit. To my understanding the matching circuit is there to have the same impedance value of the antenna, correct?
So my matching circuit consist of capacitors such that XL_ant = XC_tun, correct?
When I calculate the inductance value of my designed antenna I get a value around 980 μH, which makes XL = ~83kΩ (f = 13.56 MHz). That just seems very high to me, I thought antennas were suppose to have an impedance of ~50 - 75 Ω.
My coil antenna has the following properties:
K1 = 2.34, K2 = 2.75
d_out = 33 mm
d_in = 17mm
N = 4
and I am using the equation below to calculate the inductance
LANT = K1 × μ0 × N2 × (d / (1 + K2) × p)
I have tried playing with the properties of my designed antenna to reduce the impedance but I can't seem to bring it down low enough, which makes me think I am missing something.
Any help/guidance would be greatly appreciated! Thanks.
The inductance value you are quoting seems much too high. I would expect a few microhenries.
Notice that your antenna is too small to be efficient at this frequency. Regarding matching, if you place a capacitor in series with the inductance, so that there is resonance, you are left with just the resistance. This resistance is what we must match to. It is mainly losses in the coil, but with a very small radiation resistance in series. As a rough figure, take a total resistance value of something like 1% of the reactance. This assumes a "Q" value of 100.
http://coil32.net/online-calculators/pcb-inductor-calculator.html
Shows 950 nH. Did you slip a decimal somewhere?
They are low efficency, low radiation impedance, high Q devices which means the tuning capacitor must be highly accurate and highly stable to keep them tuned to the desired frequency, once the correct value is found. Due to their low impedance, you may need a matching network to the electronics rather than just a resonating capacitor.
Thank you Tom G all agreed. Matching can be obtained by the use of one additional capacitor shunting the external circuit but it is obvious Amanno will need help with this.
Thanks for the help guys,
I currently have a matching network between the chip and the antenna using a shunt capacitor. The shunt capacitor is wired from, the node between the matching capacitor and the antenna, and ground. How do you determine the best value for the shunt? I was going to use a value very similar to what I find for the matching capacitor. Does that sound about right?
Have at it tech99. Its been too many decades since I've done this!
That is perfect, just the help I needed! Thank you!
Related to Inductance of Square Coil Antenna on PCB
1. What is Inductance of Square Coil Antenna on PCB?
The inductance of a square coil antenna on a PCB refers to the measure of the coil's ability to store magnetic energy. It is a crucial factor in determining the performance of the antenna, as it affects the resonance frequency and impedance of the antenna.
2. How is the Inductance of Square Coil Antenna on PCB calculated?
The inductance of a square coil antenna on a PCB is calculated using the formula L = µN²A/l, where L is the inductance, µ is the permeability of the material, N is the number of turns, A is the area of the coil, and l is the length of the coil.
3. What factors affect the Inductance of Square Coil Antenna on PCB?
The inductance of a square coil antenna on a PCB is affected by several factors, including the number of turns in the coil, the size and shape of the coil, the material used for the core, and the distance between the turns.
4. How does the Inductance of Square Coil Antenna on PCB impact antenna performance?
The inductance of a square coil antenna on a PCB plays a crucial role in determining the antenna's resonance frequency and impedance, which affects its ability to transmit and receive signals effectively. A higher inductance can lead to a higher resonance frequency, while a lower inductance can result in a lower resonance frequency.
5. Can the Inductance of Square Coil Antenna on PCB be adjusted?
Yes, the inductance of a square coil antenna on a PCB can be adjusted by changing the number of turns, the size and shape of the coil, and the distance between the turns. Using different materials for the coil's core can also affect its inductance. However, it is essential to carefully consider these changes to maintain the antenna's optimal performance.
  • Electrical Engineering
  • Electromagnetism
9K
