Induction Coils and/or Hertz Experiment
In summary, the conversation discusses the voltage output of an induction coil and the relationship between sparks and oscillating electric fields. The main focus is on the changing nature of the electric field and its role in producing electromagnetic waves. The concept of Fourier transform is mentioned as a way to mathematically describe this relationship.
aku2590
Hi everyone,
Just a quick question that was bugging me...
If i was asked to draw the voltage output vs time of an induction coil...would it be absolute value sine curve??
Secondly i absolutely don't understand how in Hertz experiment, what the sparks jumping across have anything to do with oscillating electric field. If the source of the voltage is from an induction coil...then on electrode is always positive and the other always negative. The only change is that they vary from high potential difference to zero continuously (assuming my question 1 hypothesis is right).
So there is an electric field, then there isnt, then there is, then there isn't and so on...but whenever there is...its always in the same direction. So how is the EM wave produced??
Really welcome and appreciate anybody's help...
The important point is not the oscillating field, it is the changing field.
Changing rapidly in a "spark" is like changing rapidly in a high frequency oscillating field, the difference is that oscillating implies frequent repetition of this changing field.
For the exact mathematical description, try to look for Fourier transform.
This will show you how any signal, even limited in time, can be seen as a superposition of oscillating signals.
Hi there,
To answer your first question, the voltage output of an induction coil can indeed be represented by an absolute value sine curve. This is because the induction coil works by creating a changing magnetic field, which in turn induces a changing voltage in the coil. This changing voltage will result in a sine wave when graphed over time.
As for your second question, the Hertz experiment is based on the concept of electromagnetic waves, which are produced by oscillating electric and magnetic fields. In this experiment, the induction coil is used to create an oscillating electric field, which causes the sparks to jump across the gap between the electrodes. This is because the electric field is strong enough to ionize the air between the electrodes, creating a conductive path for the sparks to travel. The changing electric field also creates a changing magnetic field, which then produces the electromagnetic wave. The direction of the electric field may seem to be constant, but it is actually changing rapidly, creating the necessary conditions for electromagnetic wave production.
I hope this helps clarify your understanding of these concepts. Keep exploring and asking questions!
Related to Induction Coils and/or Hertz Experiment
1. What is an Induction Coil?
An induction coil is an electrical device that is used to generate high voltage pulses from a low voltage direct current (DC) source. It consists of a primary coil, a secondary coil, and an iron core. When a DC current is passed through the primary coil, it creates a changing magnetic field which induces a high voltage in the secondary coil.
2. How does an Induction Coil work?
An induction coil works on the principle of electromagnetic induction. When a DC current is passed through the primary coil, it creates a changing magnetic field. This changing magnetic field induces a high voltage in the secondary coil, which can be much higher than the voltage in the primary coil. This high voltage pulse can then be used for various applications such as spark plugs, ignition systems, or medical equipment.
3. What is the Hertz Experiment?
The Hertz Experiment, also known as the Hertzian Experiment, was a series of experiments conducted by German physicist Heinrich Hertz in the late 19th century. It was the first experimental proof of the existence of electromagnetic waves, which were predicted by James Clerk Maxwell's theory of electromagnetism. Hertz's experiments involved the use of induction coils and spark gaps to produce and detect electromagnetic waves.
4. What is the significance of the Hertz Experiment?
The Hertz Experiment was significant because it provided the first experimental evidence for the existence of electromagnetic waves, which are now known to be an essential part of our understanding of physics and technology. Hertz's experiments also paved the way for the development of wireless communication technologies, such as radio, television, and cell phones.
5. How are Induction Coils and the Hertz Experiment connected?
Induction coils were an essential component in Hertz's experiments, as they were used to generate and detect the electromagnetic waves. Hertz's experiments also helped to further develop and improve the design and performance of induction coils. Without the use of induction coils, the Hertz Experiment may not have been possible, and our understanding of electromagnetism and wireless communication technologies may have been delayed.
