MHB Induction for divisibility by 10
The discussion focuses on proving that for every n∈N, the expression 34n+2 + 1 is divisible by 10 using mathematical induction. The base case is established with n = 1, confirming that the expression holds true. The inductive hypothesis assumes that the expression is divisible by 10 for n = k, and the proof then shows it is also true for n = k + 1. The participants derive that both components of the expression maintain divisibility by 10 through their calculations. The proof is concluded by demonstrating that the inductive step successfully leads to the conclusion that the original statement holds for all natural numbers n.
KOO
Show that for every n∈N, 34n+2 +1 is divisible by 10
Prove by Induction.
Attempt)
Base Case: n = 1, 3(4(1)+2) + 1 = 730
So the base case holds true.
Assume that the inequality holds for n = k
34k+2 +1 is divisible by 10
Show true for n = k+1
34(k+1)+2 + 1
34k+4+2 + 1
34 * 34k+2 + 1
81 * 34k+2 + 1
(80+1) * 34k+2 + 1
80(34k+2) + 34k+2 + 1
80(34k+2) + 34k+2 + 1 is divisible by 10 according to our induction hypotheses.What next?
Prove by Induction.
Attempt)
34(k+1)+2 + 1
34k+4+2 + 1
34 * 34k+2 + 1
81 * 34k+2 + 1
(80+1) * 34k+2 + 1
$$3^{4k+2}=3^{2(2k+1)}=9^{2k+1}=(10-1)^{2k+1}$$
Regards,
$$|\pi\rangle$$
Hi KOO! :)
Let me continue from one of your expressions:
\begin{aligned}
81 \cdot 3^{4k+2} +1
&= 81 \cdot \left(3^{4k+2} + 1\right) - 81 + 1 \\
&= 81 \cdot \left(3^{4k+2} + 1\right) - 80
\end{aligned}
Both $\left(3^{4k+2} + 1\right)$ and $80$ are divisible by $10$...
Re: Induction:
I would make my induction hypothesis $P_k$ be:
$$3^{4k+2}+1=10m_k$$ where $$m_k\in\mathbb{N}$$
Next, as my inductive step, I would look at:
$$\left(3^{4(k+1)+2}+1 \right)-\left(3^{4k+2}+1 \right)=3^{4k+2}\left(3^4-1 \right)=80\cdot3^{4k+2}$$
Adding this to $P_k$, we find:
$$3^{4(k+1)+2}+1=10m_k+80\cdot3^{4k+2}=10\left(m_k+8\cdot3^{4k+2} \right)$$
If we use the recursive definition:
$$m_{k+1}=m_k+8\cdot3^{4k+2}$$ where $$m_1=730$$
then we may write:
$$3^{4(k+1)+2}+1=10m_{k+1}$$
Thus, we have derived $P_{k+1}$ from $P_k$ thereby completing the proof by induction.
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
