Induction in electrostatic equilibrium conductor
In an electrostatically balanced conductor, both the interior and surface remain equipotential. When approaching loaded objects, the surface of the conductor continues to be an equipotential. If it were not, electric field lines could form between regions of excess positive and negative charges. Electric field lines are always perpendicular to the surface of the conductor. Any deviation would cause charge movement until equilibrium is restored.
A13235378
Consider a conductor in electrostatic equilibrium, approach if charged objects so that one region of that conductor has an excess of positive charges and another region with an excess of negative charges.
Equipotential regions
We know that both the interior and the surface of an electrostatically balanced conductor are equipotential. My question is if when we approach the loaded objects, the surface of the conductor will continue to be an equipotential. If not, then there could be a field line that left the region with an excess of positive charges going to the region with an excess of negative charges?
Correct. The electric field lines are perpendicular to the surface. If they were not, charge would move until they are perpendicular.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
