Induction motor rotor design features
The discussion revolves around the design features of induction motor rotors, particularly focusing on the purpose of rotor end ring blades and the placement of aluminum bars. The blades are believed to aid in cooling the stator winding ends. Older induction motors often had aluminum bars embedded deeper within the rotor, which may have been for mechanical strength, while newer designs place them closer to the surface to enhance efficiency and torque. The depth of these bars affects the inductance and induced current, with shallower placements yielding higher torque due to stronger magnetic flux. Overall, rotor design significantly influences the motor's performance characteristics, including starting torque and efficiency.
artis
I had to repair (change bearings) on a single phase induction motor recently and I recalled an age old question I've had.
What are the rotor end ring blades made for ?
The only reasonable answer I can come up with is - they are for cooling of the stator winding ends that extend out of the stator?
And one additional question. I've seen on older style induction motors the rotor aluminum bars, that form single loop circuits in the rotor , not visible on the rotor surface , instead they are some mm or so embedded into the rotor and the surface is completely covered by the electrical steel lamination outer surface. On newer rotors I see the aluminum bars extend to the very surface like in the picture above.
Now I would think that the closer the rotor bars are to the stator magnetic field the more flux passes through them and stronger the induction and the motor more efficient for a given size, is that true?
I assume in the older designs they did not extend the aluminum bars to the surface due to machining and mechanical issues?
One of the things that determine starting torque in an induction motor is how far down into the rotor the copper or aluminum bars are buried. Most torque occurs when they are close to the surface.
And I assume that is because the further axially inwards you go in the rotor the weaker the flux becomes therefore less induced current.
So it seems the earlier motors had the aluminum bars embedded deeper simply for mechanical strength possibly as otherwise it seems detrimental to performance
The inductance of the rotor winding(s) goes up as the conductors are buried deeper. This increases inductive reactance. Startup is when the induced current in the rotor is at the highest frequency. The higher inductive reactance limits rotor current moreso than if the rotor conductors are closer to the surface. Naturally, higher rotor current gets us higher torque.
How about this from Wikipedia:
https://en.wikipedia.org/wiki/Squirrel-cage_rotor#Structure
The shape and depth of the rotor bars can be used to vary the speed-torque characteristics of the induction motor. At standstill, the revolving magnetic field passes the rotor bars at a high rate, inducing line-frequency current into the rotor bars. Due to the skin effect, the induced current tends to flow at the outer edge of the winding. As the motor accelerates, the slip frequency decreases and induced current flows at greater depths in the winding. By tapering the profile of the rotor bars to vary their resistance at different depths, or by constructing a double squirrel cage, with a combination of high and low impedance rotor in parallel the motor can be arranged to produce more or less torque at standstill and near its synchronous speed.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
