Inductive heating and eddy currents
In summary, the individual is working on a project that uses inductive heating and has some questions around the magnetic fields and localized eddy currents. They ask about iron core vs. air core coils, the weight of the lead slug, and the depth of heating. They also ask about controlling the magnetic field.
  • #36
hutchphd said:
Worse! It then causes ohmic heating in the copper to no benefit.
AC single coil has constant ohmic heating, and so does two coils PWM 50%.
In PWM one coil is exactly the same as single AC coil. Hence, not heating any coil more than the single AC coil.
In PWM 50%, the total J wasted from wire ohms is 2x that of AC single coil. Yes, a pitfall using 50% PWM. But duly noted, the two coils in PWM drive will not heat their wire any more than the single AC coil.
But, always a but in there. That's only if it's driven balanced 50% PWM. I can easily change drive down to 25% PWM per coil, thereby less wasted J, and at 25% I am back to same wasted J as the single AC coil.
  • #37
Enjoy.
  • #38
artis said:
In induction heating you want to just constantly shuffle a B field back and forth
Please define "back and forth".
In both models the B field poles flip-flop at some frequency.
In both models dB/dt between zero B and Bmax happens.
The big diff is, in sine wave drive the dB/dt between zero B and Bmax, and Bmax down to zero B, happens much much slower.
So help me understand "back and forth".
  • #39
@MagneticMagic take no offense but you seem to be one of those people that come ask for advice but then already seem to have an answer and basically just asked the advice out of curiosity?
We told you why your method is less efficient than the one we proposed , explained the "pluses and minuses".
Now if you wish to still do it your way that is fine but then what's the point of asking?
When I said "back and forth" I just meant a B field that constantly changes in strength and flips polarity.
I suggest you try both methods , your as well as the more conventional I think you should see a difference in how fast the heating happens as well as power consumed.
Also remember that heating will be more even if the metal to be heated is within the coil not outside of it, that is simply due to B field divergence outside of coil especially if you place two coils with same polarity back to back, the field will be deflected a lot and here will be no field in the middle only at the very sides, so your not just wasting current your wasting field.
  • #40
artis said:
... especially if you place two coils with same polarity back to back, the field will be deflected a lot and here will be no field in the middle only at the very sides, ...
If the scheme had been described from the start as a push-pull driver then it would have been more obvious what was meant by the misleading “50% PWM”.
Many in this thread are convinced that the coils are driven opposed in polarity, at the same time, when the coils are in fact powered alternately, so the net field through the magnetic core really is alternating and there is no cancellation, just the reversals of alternation.
  • #41
Right , completely forgot about this one, still in this approach the OP is effectively only heating one end of the metal at a time , he could connect the coils in series and then the whole of the metal would be heated at once irrespective of his waveform but for some reason that is not an option according to OP.
  • #42
See pic in post #25.
Why would I have two coils if I was going to connect them in series NS-NS? I would just wind one coil, no?
Heating one end of the metal? The B field passes through the object. The time to heat object is not in this discussion, having to heat super fast (relatively speaking) is not a factor in my project.
And using adjective words, yes, it's a push-pull design using PWM 50% drive. I can adjust the PWM to get various push-pull characteristics, but 50% drive is easier to do in silicon.
Not just alternately, but also in opposite direction magnetically. I made it clear numerous times that both coils were not 'on' at the same time. So with all due respect to all, not sure if folks are reading the posts, or understanding them.
1st thing is, AC means "alternating current", has no hard ties to voltage.
Lenz laws also tell us the eddy current flips 180deg between +dB/dt and -dB/dt (rise of B field to fall of B field). In other words, in AC, eddy flips 180deg during every 1/2 cycle of AC, or flips twice during every 1 cycle of AC. In DC drive with just one coil, eddy only flips once per cycle. So yes, AC (alternating current = alternating B field, per 1 cycle of drive) = more eddy heating, hence when driving with just DC it's best to create alternating current, which can be done a few ways using silicon.
And to be clear, I could do the basic LC tank with one coil, but my drive circuitry allows for "instant" control of frequency and B field strength, making the drive section way more flexible than an LC tank setup.
And yes, I already understand there's Pros & Cons to everything. More flexibility for less efficiency sometimes makes the solution more attractive. I understand the efficiencies.
  • #43
Matter of choice
No, a changing B field never passes through a solid metal, that is why the eddy currents form in the first place, they resist the B field that tries to enter the material by creating their own B field which is of opposite polarity , the overall effect is that of a decrease in the primary B field strength. This is induction so think of it like a transformer analogy, your piece of metal is the secondary, just short circuited and a weird shape that it.
As I said having the B field from just one side will create eddies in just one side of the metal you will heat just one side of the metal. B field is not dumb why go through a material if it can loop around and come back to the other side of the coil... B field always forms loops back to it's source.
That I think is not true , as the sine rises from zero crossing induced current increases then peaks at sine peak and decreases back to zero as sine falls back to zero (assuming voltage/current in phase) only then when sine rises to negative peak the current reverses then reaches its negative max value and decreases again , so an eddy current changes direction once per every cycle of AC irrespective of waveform. It goes same direction during each half period just with varying strength (Amperage)
  • #44
What ties then it has? Soft and tender? None at all? I hope you do realize current is a result of voltage aka potential difference, current doesn't just run on it's own.
Well in that case you just have to move on and begin doing whatever is that which you want to do.
  • #45
It's 100% not necessary to look at voltage at all. Just graph the amps, which will be a sine wave.
I got some of my vector adds mixed up. Eddys are max when B field is zero, yet dB/dt is max when B=0 for AC.
  • #46
I would blame the misunderstandings on your cryptic description of an unusual system.
Because you could then put one coil on each side of the lead slug, in Helmoltz configuration to get an even field in the oven.
You should consider driving the inductor in series with a capacitor. That technique is used to reduce driver losses in efficient resonant converters.
Likes MagneticMagic
  • #47
Ok, slight shift to something related.
If dB/dt changes to 2*dB/dt (for the same time period), does magnitude of eddy grow 2* , or is it not linear?
70.7/25usec vs 100/6usec (sinerms = .707 * DC)
2.828 vs 16.66
5.89x bigger (faster dB/dt)
Now convert into power.
I2R = W, W*sec = J
Will normalize (for example) the sine wave drive to 1x10-9W*25usec = 40mJ
Now we have the other one, it's 5.89x bigger, but does runs much shorter.
So, (40mJ*5.89)/(25/6) = 56.54mJ
In words, the bigger dB/dt makes eddy 5.89x bigger, but that bigger dB/dt period is much shorter than the smaller dB/dt. In other words, sine wave dB/dt goes for longer than the faster dB/dt of a pulse, but power is direct proportion to period (delta t) of dB/dt.
My math shows my DC drive causes more heat than the AC sine drive, 56.54mJ vs 40mJ per 25usec period (for that normalized example)
56.54/40 = 1.4135* more heat.
So, for any Bmax, the faster you can switch it on/off (not frequency, but rather dB/dt), the more J the eddy will make.
Is my math off?
  • #48
MagneticMagic said:
Here's 10kHz. The upper is the PWM drive source, the lower shows the two coils. dB/dt is magnitudes higher than sine wave.
Can you please let us have a copy of your file.asc used for the simulation in post #33.
Change or add a .txt suffix to the file.asc to make it file.asc.txt so you can attach it to a post.
  • #49
As soon as I validate functionality of the setup, I will share. I am certain my Spice will not match the physical 100%.
  • #50
2.828 vs 16.66
5.89* bigger (faster dB/dt) <-- is this right? yes, dB/dt is 5.89* faster, eddy magnitude may go 1:1 with dB/dt, but watts do not, 5.89x bigger eddy has to follow I2R rule, so watt factor is 5.892=34.69*
I2R = W, W*sec = J
Now we have the other one, it's 5.89x bigger eddy (34.69* more watts), but does runs much shorter.
So, (40mJ*34.69)/(25/6) = 333mJ
My math shows my DC drive causes more heat than the AC sine drive, 333mJ vs 40mJ per the 25usec period (for that normalized 10kHz example).
333/40 = 8.325* more heat.
Is my math off?
Looks like I missed Watts as square of current, corrected it in red. ~8x more energy put in eddy.
Check my math.
What about input watts? Let's fix the work impedance to say 1ohm.
100A DC vs 70.7Arms-sine-AC. (same Bmax)
1002 vs 70.72
10kWDC vs 4.998kWAC-RMS
So, ~2x the input power to yield 8.325* more J in the eddy(s).
Check my math.
  • #51
Without going into the math let me refresh you with some common knowledge. The thing you are forgetting is time.Every waveform unfolds in time, yes a faster/steeper current rise produces stronger induced current which is just logical isn't it? Because you are putting more energy in per given amount of time to create the faster rise, but you can't just look at the energy put in at a given small window because you won't heat your metal with just a single pulse. You need to look at the energy put in over time.
Also take into account that your square waveform after it hits max flattens off , in this flat top section there is no more change of current so current becomes steady and that part is wasted as it produces no further induction, in a sine wave such part doesn't exist.
Also a faster dB/dt change induces stronger eddy current yes but that stronger eddy current produces a stronger back EMF which decreases the strength of the applied field. I would assume with steeper dB/dt your field will not be able to penetrate as deep as with a sine waveform.
You have to take these assumptions also into account while doing the math. So far it seems your just happy to calculate the power through the coil but calculate the power into the actual material when it's inserted.
That complicates stuff fast, and frankly I don't know the result but I suspect the benefit is not what you think it would be
  • #52
As a transformer with a centre-tapped Cu primary and a single turn resistive Pb secondary, the driver magnetising current will be VAR while the shorted turn will be real VA power. The relative magnitude of those two driver current components will be interesting. I am waiting for the LTspice model.
What are the resistivities of solid and molten lead ?
  • #53
I think also the geometry of the setup will be important as would be for any real transformer, given the OP goes with his desired geometry I suspect the B field coupling to the "secondary" aka metal to be melted piece , will be rather poor because
1) the metal is not within the coils but rather outside of them
2) only one coil is active at any given time, so B field only encompasses one side of the metal and eddy currents will set up a backEMF which will further deflect the source B field which will loop around instead.
The only way he can improve this is to use a core but at the frequencies mentioned it would have to be ferrite one.
The way I would do it I would simply make a ceramic oven that serves as a container for the metal , and simply place a larger coil around the oven as is actually done in commercial ovens whether induction or resistance ones. then the metal sits in the very middle of the coil and no fancy cores or multiple coils etc are needed also the coupling is best for what can be achieved without a core.
  • #54
Not really, they are both active since in the diagram they both share a core. It is a centre-tapped push-pull transformer driven by a B-class amplifier.
Any deflection of the B field can only be because eddy currents are present. The more deflection there is, the more heating there will be of the Pb slug.
Any core would be defeated by the wide airgap about the Pb slug. Guiding the external magnetic path is really not of great importance.
artis said:
..., and simply place a larger coil around the oven as is actually done in commercial ovens whether induction or resistance ones. then the metal sits in the very middle of the coil and no fancy cores or multiple coils etc are needed also the coupling is best for what can be achieved without a core.
That is precluded by the production line running through between the coils. On the other hand, two coils in Helmholtz series give the required gap and the even field about the Pb slug, it is in effect one coil with the sample in the middle, passing between the ends.
  • #55
I seem to have missed something, what production line ?
  • #56
MagneticMagic said:
Let me set up the application, then I will get to my questions.
Large ceramic disc about 1.5" thick and about 24" in diameter on a rotary. On the top side the disc has machined casting molds. Each mold will get a room temp slug of lead of proper volume. Inductive heating will melt the lead so it can take shape of the mold.
The idea for coils is to have two of them, "iron" core. One will be held directly over the lead slug, and one held directly below the lead slug on the bottom side of the plate.
  • #57
The resistance of the metal typically ~doubles at transition to liquid. Lead is typical
I am perplexed about why this "center tapped" excitation is interesting. The theory is linear...why should there be surprises lurking?
  • #58
Is it interesting? Maybe you can explain what perplexes you.
It is different, mostly because of the way it was originally described in terms of PWM of two separate coils at the opposite ends of the same iron core.
  • #59
A center-tapped transformer with a resistive secondary (tertiary?) is not a novel system. In fact it can be done analytically I reckon.
What are the exact question(s) under investigation? Are we looking to improve something? Its a pretty standard transformer loaded in a pretty standard way.
  • #60
Well now I see why the OP wants to have it this way, because he is using a rotary disc with molds and he wants to quickly heat up each mold and then turn the disc by an increment (servo motor drive possibly) to the next mold so he needs a system that can given the B field but at the same time allow for rotary movement , so the ordinary coil doesn't provide this.
Honestly depending on the size of the Pb in question I start to think that maybe simple resistive heating could accomplish this even faster and with less problems.
@MagneticMagic imagine something like an arc furnace only here you could make one electrode within the mold or change the mold material to something conductive and then apply a second electrode that can be lifted up or down and it touches the metallic sample in the mold.
Depending on the amperage used this will heat the sample faster because DC current heats all cross section of metal evenly at the same time.
I can't find the formula (I had one) that calculates the B field strength within an airgap if the B field strength is known for a core.
Such a wide airgap will reduce the field considerably , the ferrite core will help in this regard to make the total field strength higher
  • #61
I did exactly that.
dB/dt * time = some J
Look at B in cos function
There are 4 distinct quadrants (that last gify shows it)
0-90deg (Bmax to zero)
90-180 (zero to Bmax)
180-270 (Bmax to zero)
270-360 (zero to Bmax)
The zero point is where dB/dt is max, as shown in that last gify.
I evaluated only the 0-90deg in my math above.
0-90 has a dB/dt, or J value from eddy (in my example, J per 25usec)
The overall J in eddy per full one cycle of frequency is the 0-90 J * 4
The push-pull in DC is technically AC.
To get same Bmax you need 100A DC, or 70.7A ACRMS
My math should be correct.
