p1ayaone1
- 74
I am designing a small satellite which uses a magnetometer and some coils (which interact with Earth's magnetic field) to provide attitude control.
The strength of the geomagnetic field is 30 uT to 60 uT (according to Wolfram Alpha), and the magnetometer has a resolution of 0.015 uT.
The satellite observes the CubeSat specification, which means it is basically a 10-cm cube. It is really small.
Now I need to power this thing. What I really need is voltage regulators with the highest possible efficiency. Also, because of the magnetometer, I don't want to have inductors in the power system, because they would be "always on".
The desired output voltage is 3.3V with 150 mA absolute minimum, but I would much rather be closer to 200 mA. (It should be able to go lower than 150 mA, but that figure is the minimum maximum.
) I will probably also put a 5 to 8 V bus, but my main concern is the 3V3 bus because that's where all my electronics are powered.
The input voltage is two Li-Ion cells. These could be in series (5.5 Vmin to 8.2 Vmax) or in parallel (2.75 Vmin to 4.1 Vmax). I'm ambivalent wrt series/parallel connection, as long as the regulator is sufficiently efficient.
Linear Regulator
OK, fine, it would *work* but this is an efficiency-critical application, and I don't want to lose all that extra voltage as heat.
DC-DC Converter
Buck/boost, Sepic all use inductors. No good.
Charge Pump
There are a tiny few that support variable input voltage, but the dominant functionality is voltage inversion and voltage doubling. Also, current ratings are quite low. I suspect the solution lies in this class of DC-DC converters.
Anybody got any neat ideas?
Linear Regulator
DC-DC Converter
Charge Pump
