- #36
I like Serena
MHB
- 16,336
- 258
Femme_physics said:So, let me just take a look at the second "circuit".
If this is correct then my graph for the wave should be correct, because when the current changes direction there is no flow. So there is indeed only half a phase. No?
You seem to be mixing up voltage and current.
You're concentrating on the current and what you have drawn is indeed the graph for the current.
The graph for the voltage Vs across the coil is different.
Look at it this way.
Suppose we replace the secondary coil by a battery giving off a voltage.
If the plus pole is on the bottom, the current will *bump* against the diode and no current will flow.
The battery still gives off its voltage though.
Femme_physics said:No it won't. There is still current flowing in the other direction! So there are voltage differences across the resistors. Or "voltage drop" as we know it.
What I meant is that there are 2 states for the voltage Vs: it's positive or it's negative.
When it is positive there is indeed a voltage difference across the resistors and as you say current will flow.
When it is negative, no current will flow, so there won't be a voltage across the resistors at that time.
