Inelastic collision affecting periodic motion
In summary: The second term is still ##\frac{1}{2}mv_0^2##In summary, the ratio of amplitudes A/A0 after and before the collision is 3/2.
laurenm02
A block os mass m is attached to a horizontal spring, which is attached to a wall. The block is oscillating without friction with initiation amplitude A0 and maximum velocity v0. When the block is at its maximum amplitude (and therefore instantaneously at rest), is it struck by a second identical block, moving to the left at velocity v0, and the collision is completely inelastic.
What is the ratio of amplitudes after and before the collision A / A0
E = (1/2)kA0^2 = (1/2)kx^2 + (1/2)mv^2
m1v1 + m2v2 = (m1 + m2)v'
I first set up my conservation of momentum equation to determine v' after the collision:
0 + mv0 = 2mv'
v' = v0/2
I then tried to use my energy equation to solve for final amplitude, where the energy of the system after the collision is equal to the kinetic energy from the incoming block and the potential energy of the original system.
E2 = (1/2)(2m)(v0/2)^2 + (1/2)kA0^2 = (1/2)kA^2
Rearranging and simplifying, I've narrowed it down to:
kA^2 = (mv0^2)/2 + kA0^2
But I don't know how to get the ratio from this equation. Is there something else I should be plugging into substitute and simplify?
Try expressing ##\frac{1}{2}kA_0^2## in terms of ##V_0##
You know the max velocity of the initial oscillatory(SHM) motion.
I'm sorry, I'm not really sure how to do that? How do I figure out the max velocity?
You don't have to
So because the blocks collide at maximum potential energy, can I relate that direction to maximum kinetic energy?
(1/2)kA0^2 = (1/2)mv0^2
So A0 = √(mV0^2)/k ?
You can directly substitute this
into
so you'll get ##A## from this
and you have ##A_0## from this
laurenm02 said:
A0 = √(mV0^2)/k
I see! So my final ratio A/A0 = 1/2 ?
Could you check that?
Post you're calculations, i feel it's wrong.
So Energy after the collision = (1/2)(2m)(v0^2/4) + (1/2)kA0^2
Substituting A0 = √(mV0^2)/k
Then, E = mv0^2/4 + mv0^2 = (1/2)kA^2
Simplifying: E = (mv0^2)/2 + 2mv0^2 = kA^2
So A^2 = (5mv0^2)/2
And because the coefficient of A0 is just one, the ratio* is (5/2)?
the second term should be ##\frac{1}{2}mv_0^2##
Ahh, so instead of 5/2, it's 3/2?
You didn't take the root .
FAQ: Inelastic collision affecting periodic motion
1. What is an inelastic collision?
An inelastic collision is a type of collision between two objects in which the total kinetic energy of the system is not conserved. This means that some of the kinetic energy is transformed into other forms of energy, such as heat or sound.
2. How does an inelastic collision affect periodic motion?
Inelastic collisions can affect periodic motion by changing the kinetic energy of the system. This can cause the amplitude, frequency, or period of the motion to change, resulting in a different type of periodic motion.
3. What factors influence the impact of an inelastic collision on periodic motion?
The impact of an inelastic collision on periodic motion can be influenced by several factors, including the mass and velocity of the objects involved in the collision, as well as the type of materials and surfaces involved.
4. Can an inelastic collision completely stop periodic motion?
Yes, an inelastic collision can stop periodic motion completely if the objects involved stick together after the collision. This is because the kinetic energy of the system is completely transformed into other forms of energy, resulting in a lack of motion.
5. How can one minimize the effects of inelastic collisions on periodic motion?
One way to minimize the effects of inelastic collisions on periodic motion is by using materials or surfaces that are more elastic, meaning they can store and release energy more efficiently. Additionally, reducing the mass or velocity of the objects involved can also help minimize the impact of inelastic collisions on periodic motion.
