Inelastic Collision and Angular Momentum.
In summary, the professor gave a simple conceptual problem involving a collision between a piece of clay and a motionless stick. The questions asked involved finding the momentum in the y direction after the collision and the angular momentum of the system after the collision. To answer these questions, one must understand the concept of conservation of momentum and conservation of angular momentum. The y and z components of the momentum before the collision are zero, while the x-component is simply mv. Using conservation of momentum, the momentum after the collision can be found to be (m+M)*v_f. Using the formula for angular momentum, L = mrvsin(θ), the magnitude of the angular momentum before the collision can be found
pwkr
The professor very generally created a very simple conceptual problem as a basis for harder ones, but I don't understand how to answer it.
A piece of clay, with mass (m) and speed (v) collides with a motionless stick of length L (with uniform mass density and total mass M). The stick is aligned along the Z-axis with its center at z=0. The clay is initially moving in the x-direction. The clay collides at the stick's end at z = L/2. Assume there is no gravity or external forces.
Questions:
What is the momentum in the y direction after the collision? (the clay completely sticks to the stick upon collision).
a. 1/2(m+M)v
b. 1/2(m/M)mv
c. 2/3(L/m)mv
d. zero
e. mL/M (mv)
What is the angular momentum of the system after collision?
a. Zero
b. m(m/M)vL/2
c. 2M/m(mvL)
d. mvL
e. mvL/2
I'm unsure. I know from my textbook that L = r x p, though we really haven't done cross products so I'm unsure of what that means (it says it's mrvsin(θ), right hand rule direction)
I also know about conservation of momentum, which I assume is mv=(m+M)vf. Also I know of kinetic energy conservation and torque, which causes angular momentum to change.. but I've read my textbook 5 times and I can't understand the steps to solve this very simple problem.
At first I thought the initial answer to question 1 was zero, because if a particle moving in x collides at with an object in z, it would just rotate about the xz plane and not have any y momentum. But then I remembered that there's a right hand rule (which I don't understand much either) and I doubt the professor would put a question that didn't require calculations..
In regards to question 2, since we're given the equation L = mrvsinx, and I'm assuming that it's just mrv since the angle is 90 (plus the answers don't have any sin's). But I don't understand how that would work in an inelastic collision (why would it be a ratio of M/m or m/M?)
So my guesses are 1. D and 2. B. (because there's an M and a L/2 involved)
I'm not just interested in just the answer, if someone could try to explain to me the general concept of how it works in a simple language I would really appreciate that. Thanks for your time!
Questions:
a. 1/2(m+M)v
b. 1/2(m/M)mv
c. 2/3(L/m)mv
d. zero
e. mL/M (mv)
a. Zero
b. m(m/M)vL/2
c. 2M/m(mvL)
d. mvL
e. mvL/2
Hello pwkr. Welcome to PF !
What is the x-component of the momentum of the system before the collision ?
What is the y-component of the momentum of the system before the collision ?
What is the z-component of the momentum of the system before the collision ?
What does conservation of momentum tell you regarding the momentum of the system before the collision compared to the momentum of the system after the collision ?
To use the formula, mrvsin(θ), for angular momentum, you need to know how θ is determined. You are correct in thinking the θ approaches 90° as the piece of clay approaches the point of collision.
What is the magnitude of the angular momentum of the system immediately before the collision ? Use conservation of angular momentum to answer the 2nd question.
The right-hand rule is used to give the direction of the angular momentum vector, since angular momentum is a vector quantity, but you don't need this to answer these questions.
Hello! thank you for your reply.
Let's see:
The x-component is just linear momentum (mv)
y and z components are zero before the collision.
Conservation of momentum tells me that the momentum before the collision should be the same after collision, so overall the whole momentum should be (mv)?
I'm assuming that mv would be converted into (m+M)*r*v_f since the collision is inelastic. so.. p = mv = (m+M)*(L/2)*v_f ? but it's asking for the angular momentum and I just have a collection of formulas that represent it so in my head I find it hard to isolate. What I mean is that I only have one equation, mv=(m+M)(L/2)v_f and isolating vf and replugging it in wouldn't help me, so I wouldn't know what steps to do to find angular momentum.
I think there's a concept I'm missing that is preventing me from solving this
I just had a quick thought:
the total momentum at the end would be mv(L/2), which would mean that v (relative to the origin) would decrease based on how much length the stick has as its radius. So my I guess my final answer would just be mv(L/2) and the y component is zero. Is that right?
Let's see:
Momentum is a vector quantity, so if it is unchanged by the collision, each of its components is unchanged.
First of all, don't worry if you don't fully understand the concept of cross products or the right hand rule. These are advanced concepts that are not necessary to solve this problem.
Let's start with question 1. Remember that momentum is conserved in an inelastic collision, meaning that the total momentum before the collision is equal to the total momentum after the collision. In this case, the clay has momentum in the x-direction before the collision, but after it sticks to the stick, it will have momentum in the y-direction as well. This is because the stick will also start moving in the y-direction due to the momentum transfer from the clay. So the correct answer is e. mL/M (mv).
Moving on to question 2, we need to consider angular momentum. Angular momentum is also conserved in this system, meaning that the total angular momentum before the collision is equal to the total angular momentum after the collision. In this case, the clay has no initial angular momentum because it is moving in a straight line. However, after the collision, the stick will start rotating about its center of mass, which is at z=0. The correct answer is d. mvL.
In summary, in an inelastic collision, both momentum and angular momentum are conserved. The momentum of the system can change direction, as seen in question 1, and the angular momentum can be created or changed, as seen in question 2. I hope this helps to clarify the concept for you. If you have any further questions, don't hesitate to ask your professor or a tutor for assistance.
FAQ: Inelastic Collision and Angular Momentum.
What is an inelastic collision?
An inelastic collision is a type of collision in which the total kinetic energy of the system is not conserved. This means that the objects involved in the collision stick together or deform, resulting in a loss of kinetic energy.
What is angular momentum?
Angular momentum is a measure of an object's tendency to continue rotating, which is the product of its moment of inertia and its angular velocity. It is a conserved quantity, meaning it remains constant in the absence of external torques.
How is angular momentum conserved in an inelastic collision?
In an inelastic collision, the total angular momentum of the system is conserved. This means that the initial angular momentum before the collision is equal to the final angular momentum after the collision, even though the objects may stick together and change their rotation.
What is the difference between elastic and inelastic collisions?
In an elastic collision, both kinetic energy and momentum are conserved, meaning that the objects involved bounce off each other with no loss of energy. In an inelastic collision, only momentum is conserved and some kinetic energy is lost.
How is angular momentum related to rotational motion?
Angular momentum is a measure of the rotational motion of an object. It is directly proportional to the moment of inertia, which is a measure of how difficult it is to change the rotational motion of an object, and the angular velocity, which is the speed at which the object is rotating.
