Inelastic Collision Calculate the Percent Change in KE
In summary, the archer fires a 20g bolt with a speed of 105 m/s through a 400 g apple initially at rest. The bolt exits the apple with a speed of 45 m/s, resulting in a percent change in kinetic energy of -80% for the apple/bullet system. This was determined by using the equation ΔKE= ((.5)(m1)(Vi1)2+(.5)(m2)(Vi2)2)i -((.5)(m1)(Vf1)2+(.5)(m2)(Vf2)2)f and solving for the final velocity of the apple, which was found to be 3 m/s.
arizona1379
An archer fires a 20g bolt with a speed of105 m/s through a 400 g apple initially at rest.
The bolt exits the apple with a speed of 45 m/s. What is the percent change in kinetic energy of the apple/bullet system?
m1= 20g
Vi1= 105 m/s
Vf2= 45 m/s
m2= 400g
Vi2= 0 m/s
Vf2= ?
(m1v2+m2v2)i=(m1v2+m2v2)f
%ΔKE= 100(F-I/I)
(20g)(105 m/s)+(400g)(0 m/s)=(20g)(45 m/s)+ (400g)(vf)
2100(g)(m/s)=900(g)(m/s)+(400g)(vf)
1200g(g)(m/s)=400g(vf)
3 m/s = vf
ΔKE= ((.5)(20g)(105m/s)2+(.5)(400g)(0)2)i -((.5)(20g)(45m/s)2+(.5)(400g)(3 m/s)2)f
22050J-110250J=-88200J
100x(-88200)/110250J= -80%
Figured it out myself. :)
:::::Lashawnda:::::
You did 2100 = 900 + 400 vf and isolated it wrong at the next step.
2100-900=1200
1200/400= 3
hjelmgart said:
you did 2100 = 900 + 400 vf and isolated it wrong at the next step.
2100-900=1200
1200/400= 3
Great job on solving the problem and showing your work! It's important for scientists to show their thought process and calculations in order to support their conclusions. In this case, the percent change in kinetic energy is negative, which means that there was a decrease in kinetic energy after the collision. This makes sense, since the apple slowed down and the bolt lost some of its initial speed as it passed through the apple. Keep up the good work!
FAQ: Inelastic Collision Calculate the Percent Change in KE
What is an inelastic collision?
An inelastic collision is a type of collision where kinetic energy is not conserved. This means that the total kinetic energy of the objects before and after the collision is not the same. Inelastic collisions typically involve objects that stick together or deform upon impact.
2. How is the percent change in kinetic energy calculated in an inelastic collision?
The percent change in kinetic energy is calculated by taking the difference between the initial kinetic energy and the final kinetic energy, dividing it by the initial kinetic energy, and then multiplying by 100 to get the percentage.
3. What factors affect the percent change in kinetic energy in an inelastic collision?
The percent change in kinetic energy is affected by the mass and velocity of the objects involved in the collision. A larger mass or a higher velocity will result in a greater percent change in kinetic energy.
4. Can the percent change in kinetic energy be negative in an inelastic collision?
Yes, the percent change in kinetic energy can be negative in an inelastic collision. This occurs when the final kinetic energy is less than the initial kinetic energy, indicating that some of the kinetic energy was lost during the collision.
5. What is the significance of calculating the percent change in kinetic energy in an inelastic collision?
Calculating the percent change in kinetic energy allows us to understand the amount of energy lost or gained during a collision. This information can be used to analyze the efficiency of the collision and make predictions about the behavior of objects in future collisions.
