Inelastic collision problem - question doesn't make sense
In summary, the conversation discusses a question about a past exam paper regarding an inelastic collision between a 1500kg car and a 2500kg truck. The question asks to determine the speed of the truck just after the collision and the amount of kinetic energy lost during the collision and what it is converted into. The given information states that the car has a velocity of 13m/s after the collision, which causes confusion as inelastic collisions are expected to have both objects moving at the same speed afterwards. However, it is discovered that the collision is actually partially elastic, as evidenced by the fact that the car moves with a different velocity than the truck after the collision. This results in less energy being lost during the collision.
randomkent
Q5. A 1500kg car is traveling east @ 15.0m/s, when it crashes into a 2500kg truck traveling in the same direction @ 12m/s. The car has a velocity of 13m/s affter the collision. Assuming this is an inelastic collision, determine:
a) speed of the truck just after the collision
b) how much kinetic energy is lost during the collision. Into what is this KE converted?
m1u1 + m1u2 = m1v2 + m1v2
m1u1 + m1u2 = Vf(m1 + m2)
0.5mu^2 + 0.5mu^2 ≠ 0.5mv^2 + 0.5mv^2
This is a question from a past exam paper, and I need to know this for my upcoming exam. The solutions page uses m1u1 + m1u2 = m1v2 + m1v2 for part a to get 13.2. They then used this info to get 4200J (lost) as heat and sound for part b.
From my understanding, the answer is already given (13); because aren't inelastic collisions meant to move at the same speed? Since they are moving at different speeds it must actually be ELASTIC, but then the answer is already there and part b would be invalid because no KE would be lost... The only thing I can think of is the fact that it says JUST AFTER the collision, but still the car and truck should stick together and move at the same speed, right? m1u1 + m1u2 = Vf(m1 + m2) couldn't be used because it says the car after is 13m/s; and if they stick together they would both be @ 13.125m/s to conserve momentum...
If it were a completely inelastic collision your analysis would be correct. Both would move with the speed 13.125m/s, stuck together. The question has specified an 'inelastic' collision, but it has that the car finally moves with 13m/s. This means, the collision is partially elastic, which should have been mentioned in the question.
Yeah, I guess that is the only way for it to be correct; if it was partially elastic. If we ignored "the car has a velocity of 13m/s affter the collision" and said they both moved at 13.125m/s, 4218J would be lost which is not that much more than 4200J, but that's irrelevant anyway... However, this should actually prove that it is partially elastic shouldn't it; less energy is lost. Thanks for your help!
Yep, you got it! :smile:
I would say that the question is not properly worded and is causing confusion. Inelastic collisions do not necessarily mean that the objects involved will have the same final speed. In this case, the car and truck are traveling in the same direction, which means that the truck will have to slow down to accommodate the collision. This is why the final speed of the truck is slightly lower than the initial speed of the car. Inelastic collisions also involve the loss of kinetic energy, which is converted into other forms of energy such as heat and sound. So, the solution provided for part b is correct. However, I would suggest that you clarify with your instructor or refer to your textbook for a clear explanation of inelastic collisions. It is important to understand the concepts properly rather than just relying on the given solutions.
Related to Inelastic collision problem - question doesn't make sense
1. What is an inelastic collision?
An inelastic collision is a type of collision between two objects where kinetic energy is not conserved. This means that the total kinetic energy of the objects before the collision is not equal to the total kinetic energy after the collision.
2. How is an inelastic collision different from an elastic collision?
In an elastic collision, the total kinetic energy of the objects before the collision is equal to the total kinetic energy after the collision. This means that the objects bounce off each other without any loss of energy. In an inelastic collision, some of the kinetic energy is lost and converted into other forms of energy, such as heat or sound.
3. What is the equation for calculating the final velocities in an inelastic collision?
The equation for calculating the final velocities in an inelastic collision is m1v1 + m2v2 = (m1 + m2)v, where m1 and m2 are the masses of the two objects, v1 and v2 are their initial velocities, and v is their final velocity.
4. Can an inelastic collision be perfectly inelastic?
Yes, an inelastic collision can be perfectly inelastic, which means that the two objects stick together after the collision and move as one object with a common final velocity.
5. Why is it important to understand inelastic collisions?
Understanding inelastic collisions is important in fields such as physics and engineering, as it helps us to analyze and predict the behavior of objects in real-world situations. It also allows us to design and build structures and machines that can withstand and absorb the energy from inelastic collisions.
