Inelastic collisions between two blocks
In summary, two blocks with masses of 2.0 kg and unknown mass collide on a frictionless surface, with the first block sliding at 1.0 m/s and the second block sliding at 4.0 m/s. After the collision, the blocks stick together and have a final velocity of 2.0 m/s. Using the law of conservation of momentum, it can be determined that the mass of the second block is 1.0 kg.
lilblevs11
A 2.0 kg block slides along a frictionless surface at 1.0 m/s. A second block, sliding at a faster 4.0 m/s, collides with the first from behind and sticks to it. The final velocity of the combined blocks is 2.0 m/s. What is the mass of the second block?
law of conservation of momentum...
m1u1 + m2u2 = m1v1 + m2v2
(2 kg * 1 m/s ) + (m2 * 4 m/s) = (2kg + m2) 2.0 m/s
2 J + (4 m/s m2) = 4 J + (2.0 m/s m2)
4 m/s m2 = 2 J + (2.0 m/s m2)
now I'm lost...
Just finish your algebra
by the way kgm/sec is not joule, it's just kg m/sec, which is the same as N sec
so you have the equivalent of
4m = 2 + 2m
subtracting 2m from both sides
2m = 2
m = 1kg
Thanks netgypsy... now i feel like a true student. haha
Good job!
I would like to point out that the approach taken in the solution attempt is correct, but the units used in the calculations are incorrect. The unit for momentum is kg*m/s, not J (Joules). Therefore, the correct equation should be:
(m1u1 + m2u2) = (m1v1 + m2v2)
(2 kg * 1 m/s) + (m2 * 4 m/s) = (2 kg * 2.0 m/s) + (m2 * 2.0 m/s)
2 kg*m/s + 4 m2/s = 4 kg*m/s + 2 m2/s
2 m2/s = 2 kg*m/s
m2 = 1 kg
Therefore, the mass of the second block is 1 kg. This means that the second block is half the mass of the first block. This result is consistent with the fact that the final velocity of the combined blocks is closer to the initial velocity of the first block (1 m/s) than the initial velocity of the second block (4 m/s). This indicates that the first block has a greater influence on the final velocity, which is expected since it has a greater mass.
Related to Inelastic collisions between two blocks
What is an inelastic collision?
An inelastic collision is a type of collision in which the total kinetic energy of the system is not conserved. This means that some energy is lost in the form of heat, sound, or deformation of the objects involved.
What is the difference between an inelastic and an elastic collision?
In an elastic collision, the total kinetic energy of the system is conserved. This means that the objects involved bounce off each other without any loss of energy. In an inelastic collision, some energy is lost and the objects may stick together or deform upon impact.
How is momentum conserved in an inelastic collision?
Momentum is conserved in an inelastic collision because the total momentum of the system before and after the collision remains the same. This means that the sum of the momentums of the two blocks before the collision is equal to the sum of the momentums after the collision.
What factors affect the amount of energy lost in an inelastic collision?
The amount of energy lost in an inelastic collision depends on the materials and masses of the objects involved, as well as the speed and angle of the collision. Objects with more elastic materials and lower masses will tend to lose less energy in an inelastic collision.
How are inelastic collisions used in real-world applications?
Inelastic collisions are used in many real-world applications, such as car crashes, sports equipment, and industrial machinery. In these scenarios, the loss of energy in an inelastic collision can be harnessed for specific purposes, such as reducing impact forces or transferring energy to perform work.
