Inequalities of complex number
In summary, it is not possible to define the symbol '<' for complex numbers in the same way as it is defined for real numbers. However, there are other preorders that can be applied to the complex numbers.
Einstein's Cat
182
I am under the impression that the following cannot be stated,
a < b, if the a term is a complex number and the b term is either a natural number or a complex number, or any other type of number for that matter.
Firstly am I correct? Secondly, if I am, does there exist a theorem of some sort that proves this statement here? Finally, can this be generalised to all inequalities?
Mathematics news on Phys.org
The complex numbers form a plane not a line, so are not ordered. You cannot line them all up in order, in other words.
Likes FactChecker
Yet say in the plane there are two points, a and b (or two complex numbers) and they are both points on the same line. Could not one say that the point further from another point on the line (point c) towards the positive quadrant is greater than the other point?
Analogous to the point (6,6) being further from the origin than point (1,1) on the line y = x; therefore 6 > 1.
At a basic level, the complex numbers are not ordered, in the sense that there is not a total order. The real question is what properties you expect ##<## to have. See, for example:
https://en.wikipedia.org/wiki/Total_order
You could order the complex numbers by magnitude, by real part, by imaginary part, but in all cases you get many different numbers that cannot be put in order. They are all the "same" when it comes to comparing them.
You can also do it in ways that not all numbers are "comparable". For example, if you only compare numbers with the same imaginary part, then you have a partial order. That means that you can't compare ##2 + i## with ##3 - i##, but you could say that ##2 + i < 3 + i##.
See:
https://en.wikipedia.org/wiki/Partially_ordered_set
You can define ">" for complex numbers in many ways, but none of those definitions is useful enough to be used widely.
The short answer is: ##\; a > 0 \,\wedge \, b>0 \Rightarrow ab>0## is one of the defining conditions for an ordering on a field. (Definition in my copy of van der Waerden's Algebra I)
The shorter is: All squares have to be positive in ordered fields.
The shortest is: ##\; i^2 < 0##.
With the meaning of '<' that you are probably thinking of, you are correct.
When you ask about "generalizing to all inequalities", there are more general uses of the symbol '<' in what are called 'preorders' that can be applied to the complex numbers. For instance, a < b iff |a| < |b| is a preorder. That would put two complex numbers in the same equivalance class if their modulus was equal. (see https://en.wikipedia.org/wiki/Preorder ) There are many other preorders that can be defined on the complex numbers. I assume that this was not what you had in mind. It does not satisfy the antisymetric property: a ≤ b and b ≤ a implies a = b.
Related to Inequalities of complex number
1. What is the definition of an inequality of complex numbers?
An inequality of complex numbers is a mathematical statement that compares two complex numbers using the symbols <, >, ≤, or ≥. It indicates that one complex number is either smaller than, larger than, less than or equal to, or greater than or equal to the other complex number.
2. How do you graph an inequality of complex numbers?
To graph an inequality of complex numbers, the real and imaginary parts of the complex numbers are plotted on an Argand diagram. The points are then connected with a line or a curve, depending on the type of inequality, and the region of the complex plane that satisfies the inequality is shaded.
3. What is the solution set of an inequality of complex numbers?
The solution set of an inequality of complex numbers is the set of all complex numbers that satisfy the given inequality. It may be represented graphically on the complex plane or as a set of complex numbers in the form of a set-builder notation.
4. How do you solve an inequality of complex numbers algebraically?
To solve an inequality of complex numbers algebraically, the real and imaginary parts of the complex numbers are compared and the inequality is solved using the same methods as solving equations. The solution set is then written in the form of a set-builder notation.
5. What is the difference between absolute value inequality and complex number inequality?
An absolute value inequality compares the magnitudes of two numbers without considering their signs, while a complex number inequality compares the real and imaginary parts of two complex numbers. Additionally, complex number inequalities involve both real and imaginary numbers, while absolute value inequalities only involve real numbers.
