Inequality challenge for all positive (but not zero) real a, b and c
In summary, the inequality challenge for all positive (but not zero) real a, b, and c is a unique mathematical problem that involves finding the minimum value of an expression. This is different from other mathematical problems which typically involve solving for a specific value or variable. The restriction on the values of a, b, and c being positive (but not zero) is significant as it ensures the expression is always defined and avoids division by zero errors. This inequality challenge can be solved using techniques such as the AM-GM inequality, Cauchy-Schwarz inequality, or substitution methods. It has various applications in the field of science, including economics, physics, and statistics, for optimizing parameters and proving mathematical inequalities.
anemone
MHB
POTW Director
3,883
115
Prove \(\displaystyle \frac{ab}{a+b+ab}+\frac{bc}{b+c+bc}+\frac{ca}{c+a+ca}\le \frac{a^2+b^2+c^2+6}{9}\) for all positive real $a,\,b$ and $c$ and $a,\,b,\,c\ne 0$.
Mathematics news on Phys.org
Hint:
Note that \(\displaystyle \frac{ab}{a+b+ab}=\frac{1}{\frac{1}{a}+\frac{1}{b}+1}\).
my solution:
using $AP\geq HP$
We have :$\\
\dfrac{ab}{a+b+ab}\leq \dfrac{a+b+1}{9}---(1)\\
\dfrac{bc}{b+c+bc}\leq \dfrac{b+c+1}{9}---(2)\\
\dfrac{ca}{c+a+ca}\leq \dfrac{c+a+1}{9}---(3)\\
(1)+(2)+(3):\dfrac {ab}{a+b+ab}+\dfrac {bc}{b+c+bc}+\dfrac {ca}{c+a+ca}\leq\dfrac{2a+2b+2c+3}{9}\leq \dfrac{a^2+1+b^2+1+c^2+1+3}{9}= \dfrac{a^2+b^2+c^2+6}{9}$
(using $AP\geq GP$)
Well done Albert!(Cool) That is how I approached the problem as well!
FAQ: Inequality challenge for all positive (but not zero) real a, b and c
What is the inequality challenge for all positive (but not zero) real a, b, and c?
The inequality challenge for all positive (but not zero) real a, b, and c is a mathematical problem that involves finding the minimum value of the expression (a + b + c)^2 / (ab + bc + ca).
How is this inequality challenge different from other mathematical problems?
This inequality challenge is unique because it involves finding the minimum value of an expression instead of solving for a specific value or variable.
What is the significance of the restriction on the values of a, b, and c?
The restriction on the values of a, b, and c being positive (but not zero) ensures that the expression is always defined and avoids any division by zero errors.
Can this inequality challenge be solved using any specific mathematical techniques?
Yes, this inequality challenge can be solved using various techniques such as the AM-GM inequality, Cauchy-Schwarz inequality, or substitution methods.
What are some applications of this inequality challenge in the field of science?
This inequality challenge can be applied in various fields of science such as economics, physics, and statistics to find the minimum value of a given expression and optimize certain parameters. It can also be used in optimization problems and in proving other mathematical inequalities.
