MHB Inequality challenge for positive real numbers
The discussion centers on proving the inequality 2(√2 - 1)a² - b² < 1 under the condition that a and b are positive real numbers satisfying a³ + b³ = a - b. Participants agree that equality will never hold in this scenario. There is a consensus that the original problem statement needed correction to reflect that it should not imply a tight inequality. The conversation highlights the importance of accurately framing mathematical problems. Overall, the focus is on establishing the inequality while clarifying the conditions under which it holds.
anemone
MHB
POTW Director
If $a$ and $b$ are two positive real, and that $a^3+b^3=a-b$, prove that $2\left(\sqrt{2}-1\right)a^2-b^2\lt 1$.
Mathematics news on Phys.org
anemone said:
If $a$ and $b$ are two positive real, and that $a^3+b^3=a-b$, prove that $2\left(\sqrt{2}-1\right)a^2-b^2\le 1$.
it should be:If $a$ and $b$ are two positive real, and that $a^3+b^3=a-b$, prove that $2\left(\sqrt{2}-1\right)a^2-b^2<1$.
$a^3+b^3=a-b>0 \,\,\therefore a>b$,
$a-a^3=b+b^3>0,\therefore a<1$
we have:$0<b<a<1$
and $2\left(\sqrt{2}-1\right)a^2-b^2<2(1.5-1)\times 1^2-0^2=1$
Ah, Albert, you're absolutely right, the problem itself should not be a tight inequality. I will fix it now, and thanks for catching it!
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
