MHB Inequality Challenge: Prove $b^3+a^3 \le 2$
The discussion centers on proving the inequality $b^3 + a^3 \le 2$ given that $b^3 + a^2 \ge b^4 + a^3$ for positive reals $a$ and $b$. The proof involves showing that the region defined by the inequalities is contained within certain curves, specifically using the relationships between three curves represented by inequalities. The transition from one inequality to another is established through mathematical reasoning, including the use of Lagrange multipliers to find critical points. Ultimately, the conclusion drawn is that the initial condition leads to the desired inequality, confirming that $b^3 + a^3 \le 2$. The discussion emphasizes the complexity of the proof despite its seemingly straightforward nature.
anemone
MHB
POTW Director
The positive real $a$ and $b$ satisfy $b^3+a^2\ge b^4+a^3$. Prove that $b^3+a^3\le 2$.
Mathematics news on Phys.org
It ought to be easier than this!
[sp][graph]iubck9bicm[/graph] (Click on the diagram for an enlargement.)
This is based on the idea that, within the positive quadrant, the region enclosed by the brown curve (1) is contained in the interior of the green circle (2), which in turn is contained in the the region enclosed by the blue curve (3). These regions are given by the inequalities $x\geqslant0$, $y\geqslant0$, together with $$(1)\quad x^2 - x^3 + y^3 - y^4 \geqslant0,$$ $$(2)\quad x+y-x^2 - y^2 \geqslant0,$$ $$(3)\quad 2 - x^3 - y^3 \geqslant0.$$ To show that (1) implies (2), we need to show that $x+y-x^2 - y^2 \geqslant x^2 - x^3 + y^3 - y^4.$ That is equivalent to $x-2x^2 + x^3 + y - 2y^2 + y^3 = x(1-x)^2 + y(1-y)^2 \geqslant0$, which is obviously true when $x\geqslant0$ and $y\geqslant0.$
I thought that it ought to be easier to prove that (2) implies (3), because the green and blue curves have a more regular shape than the brown one. But the only way I can see to prove $(2)\Rightarrow(3)$ is to use Lagrange multipliers. In fact, to minimise the distance from a point on the blue curve to the centre of the green circle, we have to minimise $f(x,y) = \bigl(x-\frac12\bigr)^2 + \bigl(y-\frac12\bigr)^2$ subject to the condition $x^3+y^3 = 2$. To do that, put the partial derivatives of $f(x,y) - \lambda(x^3+y^3-2)$ equal to zero. That gives $$2x+1 - 3\lambda x^2 = 0,\qquad 2y-1 - 3\lambda y^2 = 0,$$ from which $\dfrac{2x-1}{x^2} = \dfrac{2y-1}{y^2}$. That reduces to $(x-y)(2xy-x-y) = 0$. You can check that the only point on the curve $x^3+y^3 = 2$ satisfying either of the conditions $x-y=0$ or $2xy-x-y=0$ is the point $(1,1)$. Therefore the blue curve lies entirely outside the green circle except at that one point. That is equivalent to the implication $(2)\Rightarrow(3)$.
Since $(1)\Rightarrow(2)$ and $(2)\Rightarrow(3)$, it follows that $(1)\Rightarrow(3)$. In particular, if you put $(x,y) = (a,b)$, it follows that $b^3+a^2\geqslant b^4+a^3$ implies $b^3+a^3\leqslant 2$.[/sp]
Thanks for participating, Opalg! This is a very good solution that is so well explained. I salute you for this.:)
Solution proposed by other:
This is equivalent in asking us to show that if $b^3+a^3>2$, then we must have $b^3+a^2<b^4+a^3$.
Power-Mean inequality tells us
$\sqrt[3]{\dfrac{b^3+a^3}{2}}\ge \sqrt[2]{\dfrac{b^2+a^2}{2}}$
Rearrange and manipulate the inequality above we get
$\left( \dfrac{b^3+a^3}{2} \right)^{\dfrac{2}{3}}(2) \ge b^2+a^2$
$(b^3+a^3)^{\dfrac{2}{3}}(2)^{\dfrac{1}{3}} \ge b^2+a^2$
Since $b^3+a^3>2$, we can say that
$(b^3+a^3)^{\dfrac{2}{3}}(b^3+a^3)^{\dfrac{1}{3}} \ge b^2+a^2$
$b^3+a^3 \ge b^2+a^2$
$\therefore b^3-b^2 \ge a^2-a^3$
On the other hand, note that $b^2(b-1)^2 \ge 0$, this gives $b^4-b^3 \ge b^3-b^2$.
Hence we get
$b^4-b^3 \ge a^2-a^3$
$b^4+a^3\ge b^3+a^2$
$b^3+a^2<b^4+a^3$, proving the case.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
