MHB Inequality Challenge: Show $7x+12xy+5y \le 9$
The discussion focuses on proving the inequality $7x + 12xy + 5y \le 9$ under the condition $9x^2 + 8xy + 7y^2 \le 6$. A graphical representation shows that the ellipse defined by the first inequality is contained within the region defined by the hyperbola of the second inequality. The point of tangency at $(1/2, 1/2)$ indicates that the two curves share a common tangent with a specific gradient. Participants acknowledge the value of both graphical and algebraic approaches to solving the problem. The conversation highlights the interplay between geometry and algebra in understanding inequalities.
anemone
MHB
POTW Director
Let $x, y$ be real numbers such that $9x^2+8xy+7y^2 \le 6$.
Show that $7x+12xy+5y \le 9$.
Mathematics news on Phys.org
[sp]
[graph]1hbxwofxmo[/graph] [Click on the graph for a larger version.]
The blue curve is the ellipse $9x^2+8xy+7y^2 = 6$. The brown curve is the hyperbola $7x+12xy+5y = 9$. They share a common tangent at the point $(1/2,1/2)$, with gradient $-13/11.$ The interior of the ellipse is the region $9x^2+8xy+7y^2 \leqslant 6$, and the region between the two branches of the hyperbola is given by $7x+12xy+5y \leqslant 9$. From the geometry, it is clear that the first of those regions is contained in the second. I don't see a neat way to prove that algebraically, but I think this is one of those cases where a picture says more than an equation could.[/sp]
Show that $7x+12xy+5y \le 9$.---(2)
Let $x, y$ be real numbers such that $9x^2+8xy+7y^2 \le 6 ----(1)$.
in fact we only have to discuss :x>0, and y>0
$9x^2+8xy+7y^2 \le 9x^2+4x^2+4y^2+7y^2$ (GM$\le AM)$
the equivalence exists only if x=y
so we have :$24x^2\le 6$
$\therefore x=y\le \dfrac{1}{2}$
$\therefore $ the left side of (2) :$\dfrac{7}{2}+\dfrac{12}{4}+\dfrac{5}{2}\le 9$
Thank you to both of you, Opalg and Albert for participating. It's good to know there are many ways(graphical/algebraic) to solve a problem.
I think the solution proposed by other that wanted to share here is very similar to the concept of Albert, let's see:
If we let $x=a+\dfrac{1}{2}$ and $y=b+\dfrac{1}{2}$, where $a, b \in R$, the given inequality becomes
$9\left( a+\dfrac{1}{2} \right)^2+8\left( a+\dfrac{1}{2} \right)\left( b+\dfrac{1}{2} \right)+7\left( b+\dfrac{1}{2} \right)^2 \le 6$
$13a+11b+8ab \le -(9a^2+7b^2)$
The inequality that we wanted to prove, its LHS after undergo the transformation turns to
$7x+12xy+5y=7\left( a+\dfrac{1}{2} \right)+12\left( a+\dfrac{1}{2} \right)\left( b+\dfrac{1}{2} \right)+5\left( b+\dfrac{1}{2} \right)=13a+11b+8ab+9 \le 9-(9a^2+7b^2) \le 9$
Adding 9 to both sides of the inequality $13a+11b+8ab \le -(9a^2+7b^2)$ gives
$7x+12xy+5y=13a+11b+8ab+9 \le 9-(9a^2+7b^2) \le 9$
and we are done.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
