MHB Inequality of logarithm function
The discussion centers on proving the inequality involving logarithmic functions of real numbers a, b, and c, constrained by the condition a + b + c = 9. The inequality to be proven is that the sum of the square roots of the logarithmic expressions is less than or equal to 3√6. Participants engage in deriving the proof and exploring the properties of logarithms to establish the validity of the inequality. The conversation highlights the mathematical techniques and reasoning necessary to tackle such inequalities. The proof ultimately confirms the stated inequality holds under the given conditions.
anemone
MHB
POTW Director
Let the reals $a, b, c∈(1,\,∞)$ with $a + b + c = 9$.
Prove the following inequality holds:
$\sqrt{(\log_3a^b +\log_3a^c)}+\sqrt{(\log_3b^c +\log_3b^a)}+\sqrt{(\log_3c^a +\log_3c^b)}\le 3\sqrt{6}$.
Mathematics news on Phys.org
for:
$\log_3a^b >0,\log_3a^c>0,$
$\log_3b^a >0,\log_3b^c>0,$
$\log_3c^a >0,\log_3c^b>0,$
here $a, b, c∈(1,\,∞)$
if $a=b=c=3$ then equality holds
if $a=b=1,c=7$ then
$\sqrt{(\log_3a^b +\log_3a^c)}+\sqrt{(\log_3b^c +\log_3b^a)}+\sqrt{(\log_3c^a +\log_3c^b)}=\sqrt{(\log_37+\log_37)}<3\sqrt 6$
and $3\sqrt 6$ is a maximum value
Thanks Albert for participating!
My solution:
By applying the Cauchy-Schwarz inequality to the LHS of the intended inequality gives
$$\sqrt{(\log_3a^b +\log_3a^c)}+\sqrt{(\log_3b^c +\log_3b^a)}+\sqrt{(\log_3c^a +\log_3c^b)}$$
$$\le \sqrt{1+1+1}\sqrt{\log_3a^b +\log_3a^c+\log_3b^c +\log_3b^a+\log_3c^a +\log_3c^b}$$
$$=\sqrt{3}\sqrt{\log_3a^a +\log_3a^b+\log_3a^c+\log_3b^a +\log_3b^b+\log_3b^c+\log_3c^a +\log_3c^b+\log_3c^c-\log_3a^a-\log_3b^b-\log_3c^c}$$
$$=\sqrt{3}\sqrt{\log_3a^{a+b+c} +\log_3b^{a+b+c} +\log_3c^{a+b+c} -(\log_3a^a+\log_3b^b+\log_3c^c})$$
$$=\sqrt{3}\sqrt{(a+b+c)\log_3abc -(\log_3a^a+\log_3b^b+\log_3c^c})$$
$$=\sqrt{3}\sqrt{9\log_33^3 -(\log_3a^a+\log_3b^b+\log_3c^c})$$ since $$a+b+c=9\ge 3\sqrt[3]{abc}\implies abc \le 3^3$$
$$=\sqrt{3}\sqrt{27 -(a\log_3a+b\log_3b+c\log_3c})$$
Now, if we're to study the nature of the function for $$f(a)=a\log_3 a$$, we know it's a concave up and an increasing function, we could use the Jensen's inequality to figure out the minimum of $$a\log_3a+b\log_3b+c\log_3c$$:
$$\frac{a\log_3a+b\log_3b+c\log_3c}{3}\ge \frac{a+b+c}{3}\log_3\left(\frac{a+b+c}{3}\right)=\frac{9}{3}\log_3\left(\frac{9}{3}\right)=3$$
$$\therefore a\log_3a+b\log_3b+c\log_3c=3(3)=9$$
Now we get the maximum of the LHS of the intended inequality as:
$$\begin{align*}\sqrt{(\log_3a^b +\log_3a^c)}+\sqrt{(\log_3b^c +\log_3b^a)}+\sqrt{(\log_3c^a +\log_3c^b)}&\le \sqrt{3}\sqrt{27 -(a\log_3a+b\log_3b+c\log_3c})\\& \le \sqrt{3}\sqrt{27 -9}\\&=\sqrt{3}\sqrt{18}\\&=\sqrt{9}\sqrt{6}\\&=3\sqrt{6}\end{align*}$$
with equality when $$a=b=c=3$$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
