MHB Inequality Of The Sum Of A Series
anemone
MHB
POTW Director
Prove $$\frac{10}{\sqrt{11^{11}}}+\frac{11}{\sqrt{12^{12}}}+\cdots+\frac{2015}{\sqrt{2016^{2016}}}\gt \frac{1}{10!}-\frac{1}{2016!}$$
Mathematics news on Phys.org
Hi anemone,
Here is my solution.
Let $n\in \{11,\ldots, 2016\}$. Then $n!^2$ is the product of $k(n+1-k)$ as $k$ ranges from $1$ to $n$. Consider the inequality $$xy\ge x + y - 1 \qquad (x,y\in \Bbb N)$$ which follows from the inequality $(x - 1)(y - 1) \ge 0$. Since equality holds above if and only if $x = 1$ or $y = 1$, we find that $k(n+1-k) > k + (n+1-k) - 1 = n$ for $1 < k < n$. Therefore $n!^2 > n^n$, or $\sqrt{n^n} < n!$. I now estimate
$$\frac{10}{\sqrt{11^{11}}} + \frac{11}{\sqrt{12^{12}}} + \cdots + \frac{2015}{\sqrt{2016^{2016}}}$$
$$=\sum_{n = 11}^{2016} \frac{n-1}{\sqrt{n^n}} > \sum_{n = 11}^{2016} \frac{n-1}{n!} = \sum_{n = 1}^{2016} \left(\frac{1}{(n-1)!} - \frac{1}{n!}\right),$$
which telescopes to $$\frac{1}{10!} - \frac{1}{2016!}.$$
Euge said:
Hi anemone,
Let $n\in \{11,\ldots, 2016\}$. Then $n!^2$ is the product of $k(n+1-k)$ as $k$ ranges from $1$ to $n$. Consider the inequality $$xy\ge x + y - 1 \qquad (x,y\in \Bbb N)$$ which follows from the inequality $(x - 1)(y - 1) \ge 0$. Since the above equality holds if and only if $x = 1$ or $y = 1$, we find that $k(n+1-k) > k + (n+1-k) - 1 = n$ for $1 < k < n$. Therefore $n!^2 > n^n$, or $\sqrt{n^n} < n!$. I now estimate
Spectacular, Euge! And thanks for participating!(Cool)
Euge said:
Hi anemone,
marvelous !
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
