Inequality Proof: $\dfrac{2015}{(k+1)(k+4030)}<\dfrac{1}{k+1}$
In summary, the inequality $\dfrac{2015}{(k+1)(k+4030)}<\dfrac{1}{k+1}-\dfrac{1}{k+2}+\dfrac{1}{k+3}-\dfrac{1}{k+4}+\cdots+\dfrac{1}{k+4029}-\dfrac{1}{k+4030}$ is a special case of a more general inequality that can be proved by induction. The base case is when $n=1$, where the inequality becomes an equality. The inductive step involves showing that the inequality holds for $n+1$ by multiplying both sides by polynomials in $k$ and
anemone
MHB
POTW Director
3,883
115
Suppose $k>0$. Show that $\dfrac{2015}{(k+1)(k+4030)}<\dfrac{1}{k+1}-\dfrac{1}{k+2}+\dfrac{1}{k+3}-\dfrac{1}{k+4}+\cdots+\dfrac{1}{k+4029}-\dfrac{1}{k+4030}$.
Mathematics news on Phys.org
[sp]This is a special case ($n=2015$) of the inequality $$\frac n{(k+1)(k+2n)} < \frac{1}{k+1}-\dfrac{1}{k+2}+\dfrac{1}{k+3}-\dfrac{1}{k+4}+\ldots+\dfrac{1}{k+2n-1}-\dfrac{1}{k+2n},$$ which can be proved by induction for $n\geqslant2$.
In fact, the result almost holds for $n=1$ too, except that in this case the inequality becomes an equality, because $\dfrac1{(k+1)(k+2)} = \dfrac1{k+1} - \dfrac1{k+2}.$ So we can take this as the base case, provided that the proof of the inductive step involves a strict inequality. That will establish that the strict inequality occurs when $n=2$.
So suppose that the inequality holds for some value of $n$. Then $$\frac n{(k+1)(k+2n)} + \dfrac1{k+2n+1} - \dfrac1{k+2n+2} < \frac{1}{k+1}-\dfrac{1}{k+2}+\dfrac{1}{k+3}-\dfrac{1}{k+4}+\ldots+\dfrac{1}{k+2n+1}-\dfrac{1}{k+2n+2}.$$ Since $\dfrac1{k+2n+1} - \dfrac1{k+2n+2} = \dfrac1{(k+2n+1)(k+2n+2)},$ the left side of that inequality is equal to $\dfrac n{(k+1)(k+2n)} + \dfrac1{(k+2n+1)(k+2n+2)}.$
To establish the inductive step, we therefore need to show that $$\dfrac{n+1}{(k+1)(k+2n+2)} < \frac n{(k+1)(k+2n)} + \dfrac1{(k+2n+1)(k+2n+2)}.$$ Multiplying out the fractions, this is equivalent to showing that $$(n+1)(k+2n)(k+2n+1) < n(k+2n+1)(k+2n+2) + (k+1)(k+2n).$$ Now write both sides as polynomials in $k$ to see that this is equivalent to showing that $$(n+1)k^2 + (4n^2 + 5n + 1)k + 2n < (n+1)k^2 + (4n^2 + 5n + 1)k + 4n.$$ But since $4n>2n$, that last inequality obviously holds. That (somewhat inelegantly) establishes the inductive step and proves the result.[/sp]
Thanks for participating in this challenge, Opalg!
The solution that I have also prove the inequality with the induction method!(Smile)
FAQ: Inequality Proof: $\dfrac{2015}{(k+1)(k+4030)}<\dfrac{1}{k+1}$
What is the purpose of the inequality proof?
The purpose of the inequality proof is to show that the expression $\dfrac{2015}{(k+1)(k+4030)}<\dfrac{1}{k+1}$ is always true for any values of k. This can be used to solve problems involving inequalities in mathematics and other fields.
How do you solve the inequality proof?
To solve the inequality proof, we first need to manipulate the expression to isolate k on one side of the inequality sign. Then, we can use algebraic techniques to simplify the expression and prove that it is always true for any values of k. This may involve factoring, combining like terms, and using properties of inequalities.
What assumptions are made in the inequality proof?
The inequality proof assumes that the expressions $\dfrac{2015}{(k+1)(k+4030)}$ and $\dfrac{1}{k+1}$ are well-defined for all values of k. It also assumes that all basic properties of arithmetic and algebra, such as the commutative and associative properties, hold true for these expressions.
Can the inequality proof be used for any other expressions?
Yes, the techniques used in the inequality proof can be applied to other similar expressions involving inequalities. However, the specific values and variables used in the expression may change the approach needed to solve the proof.
What are the real-world applications of the inequality proof?
The inequality proof can be used in various fields, such as economics, statistics, and physics, to analyze and solve problems involving inequalities. It can also be used to make predictions and decisions based on data and trends in a given scenario.
