MHB Inequality proof w/ induction, 2 unknowns
The discussion centers on proving the inequality \((1+x)^n \geq 1 + nx\) for real \(x > -1\) and natural numbers \(n \geq 2\) using mathematical induction. The base case for \(n=2\) is established as true, showing \((1+x)^2 \geq 1 + 2x\). The inductive step involves assuming the statement holds for \(n=m\) and proving it for \(n=m+1\). The proof is completed by manipulating the expression \((1+x)^{m+1}\) and applying the inductive hypothesis, ultimately confirming that the inequality holds. The participants successfully clarify the steps needed to complete the proof, emphasizing the importance of constructing inequalities during the induction process.
skate_nerd
I am given a statement to prove: Show (without using the Binomial Theorem) that \((1+x)^n\geq{1+nx}\) for every real number \(x>-1\) and natural numbers \(n\geq{2}\). I am given a hint to fix \(x\) and apply induction on \(n\).
I started by supposing \(x\) is a fixed, real number larger than -1, and then calling the given formula \(P(n)\), and evaluating \(P(n)\) at the base case \(n=2\).
This gives \((1+x)^2\geq{1+2x}\) which can be rewritten as \(1+2x+x^2\geq{1+2x}\).
It is know that for all real \(x\), the statement \(x^2\geq{0}\) is true.
Here is where I get tripped up.
We need to assume that \(m=n\) a.k.a. \(P(m)\) is true for all natural \(m\geq{2}\).
So we have \((1+x)^m\geq{1+mx}\). Now we need to show that \(P(m+1)\) holds to be true. \(P(m+1)\):
\((1+x)^{m+1}\geq{1+(m+1)x}\).
Now here I would usually try to translate the original formula by plugging in what we had originally, but I am pretty iffy on how to do this with an inequality. If anybody could help me construct a new formula that would help me prove that
\((1+x)^{m+1}\geq{1+(m+1)x}\) is true I would be very thankful.
\displaystyle \begin{align*} \left( 1 + x \right) ^{m + 1} &= \left( 1 + x \right) \left( 1 + x \right) ^m \\ &\geq \left( 1 + x \right) \left( 1 + m\,x \right) \\ &= 1 + \left( m + 1 \right) \, x + m\,x^2 \\ &\geq 1 + \left( m + 1 \right) \, x \end{align*}
Okay, you have shown the base case is true, and so your induction hypothesis $P_m$ is:
$$(1+x)^m\ge1+mx$$
I would consider for the inductive step:
$$(1+x)^{m+1}-(1+x)^{m}=(1+x)^{m}(1+x-1)=(1+x)^{m}x$$
Can you use the inductive hypothesis to construct from this a weak inequality that you can then add to $P_m$?
Thanks to both of you for the responses. So I was actually able to figure out and finish the proof going by what Prove It wrote. But to MarkFL, what do you mean by constructing a "weak inequality"? Does that refer to the point where you find an inequality where you have \(mx^2\geq{0}\)?
What I had in mind is to take the equation:
$$(1+x)^{m+1}-(1+x)^{m}=(1+x)^{m}x$$
and then use the induction hypothesis (which we have multiplied by $x$) to write:
$$(1+x)^{m}x\ge(1+mx)x$$
so that we now have:
$$(1+x)^{m+1}-(1+x)^{m}\ge(1+mx)x$$
Adding this to $P_m$, we get:
$$(1+x)^{m+1}\ge 1+mx+(1+mx)x=1+(m+1)x+mx^2$$
Since $mx^2\ge0$, we have:
$$(1+x)^{m+1}\ge1+(m+1)x+mx^2\ge1+(m+1)x$$
And so we may conclude:
$$(1+x)^{m+1}\ge1+(m+1)x$$
Thus, we have derived $P_{m+1}$ from $P_{m}$, thereby completing the proof by induction.
Ahh I see. Yeah I ended up writing something similar to that, with the same ending. Thanks for the help guys!
I'm taking a look at intuitionistic propositional logic (IPL). Basically it exclude Double Negation Elimination (DNE) from the set of axiom schemas replacing it with Ex falso quodlibet: ⊥ → p for any proposition p (including both atomic and composite propositions). In IPL, for instance, the Law of Excluded Middle (LEM) p ∨ ¬p is no longer a theorem. My question: aside from the logic formal perspective, is IPL supposed to model/address some specific "kind of world" ? Thanks.
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
