MHB Inequality with positive real numbers a and b
anemone
MHB
POTW Director
Let $a$ and $b$ be positive real numbers such that $a+b=1$. Prove that $a^ab^b+a^bb^a\le 1$.
Mathematics news on Phys.org
We have
$1= a+ b = a^{a+b} + b^{a+b}$
So $1- (a^ab^b + a^b b^a)$
$= a^{a+b} + b^{a+b} - (a^ab^b + a^b b^a)$
$= a^a(a^b-b^b) + b^a(b^b-a^b) = (a^a - b^a)(a^b - b^b)$
For a > b both the terms are non -ve so we have and if b > a then both terms are -ve and hence above is positive
$1- (a^ab^b + a^b b^a) >=0$ and hence the result
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
