Inertia and static friction confusion
In summary, a recent physics class discussed how friction is not affected by surface area, but by the "bumpiness" of the objects and mass, and how this may not always be the case. The example of nails being harder to pull out the deeper they are embedded in a surface raises questions about the relationship between surface area and force. Additionally, the definition of inertia as a tendency for an object to remain in motion or stay still while still may not fully account for the complexities of this concept. Further experimentation is needed to fully understand the relationship between force, surface area, and depth of penetration for objects such as nails.
RyanXXVI
In a recent physics class I took, my teacher explained how friction is not affected by surface area, but by the "bumpiness" of the two objects and the mass, as well as other things, but not the surface area. But this made me wonder how nails get harder to pull out the deeper they are embedded in a surface. Since the only thing apparently increasing is the contacting surface area of the object, why does it become harder to remove?
Also, the definition of inertia is "a tendency for an object to remain in motion while in motion or to stay still while still", would the nail technically have a larger inertia in the previous example? I know that Inertia is solely dependent on mass, but shouldn't this example warrant a better definition? Thanks in advance.
http://www.eskimo.com/~billb/miscon/miscon4.html#fric
Note: the friction model taught in schools is a simple one in which there is no dependence on the surface area of contact. This need not be the case but it is often enough to make this a reasonable thing to do.
However - it is not strongly related to the bumpiness of materials.
Have you actually hammered a nail to different depths into something and then measured how hard it is to pull out or are you going by a personal impression or intuition or "because everyone says so" something? Do you have a reference of anyone doing this experiment? (It strikes me as a good one to do.)
i.e. how do you know it takes more force to get the nail moving the deeper it is?
The experience is that it take more effort ... that's different.Considering that something like wood springs back after the initial drive to grip the nail tightly, it is plausible that deeper nails require more force. The nails are not free to jounce about on the surface they have to slide against - which is required in the class model. In terms of your class model, this would be the same as the normal force depending on depth.
No better definition needed - the inertia relates the object to the force required to do something - friction is defined as a force. Encorporating some forces into the definition of inertia and leaving some out would just overcomplicate things. Leave it as it is - it has worked for centuries.
To answer your question, no I have not done the experiment (although I agree I should), and I posted this question on a poor assumption. I could have easily just confused Force for Work, which certainly would increase due to the increased distance needed to pull the nail out. However, I do have a potential way increased surface area could appear to increase necessary force. Alternatively, I could be confusing force for impulse, as it just might take a longer continuous force to pull it out. Most likely, my confusion caused this problem. However, that doesn't mean the experiment should not be done (I cannot, because I do not have access to advanced physics technology).
The experiment is very low tech.
Aim: determine relationship between force-to-move, and penetration-depth, of a nail in wood.
Equipment:
hammer, nail, wood, ruler, vice-grip pliers, wire hook, bucket, scrap metal, scales.
The highest tech devices there are the scales.
All equipment can be found in a department store.
Rough Method:
(This will need to be refined after the first few trials depending on exact equipment used.)
1. Measure the length of the nail.
2. Hammer the nail into the wood and measure how much is sticking out.
3. Fasten wood securely overhead so nail is pointing downwards - so you want a framework: clamping to ceiling beams for example (use your imagination)
4. Securely fasten the vice-grip to the nail head. (Take care not to move the nail about.)
5. Hang bucket off vice-grip.
6. Add scrap metal to bucket until you see the nail just start to move.
7. Weigh bucket.
Repeat lots of times. Try different nails and depths.
Variations: different kinds of wood
different materials (i.e. concrete - which would involve drilling a small guidehole).
Analysis:
Graph: weight vs exposed length for each nail and find the slope.
Note:
Physics does not have to involve "advanced physics technology" - though it can help.
If you want quick results, use panel pins for the nail and balsa wood.
You'll need a lighter way to fix the weights to the end of the nail than a vice grip and bucket but I'm sure you can work it out.
Thank you for sharing your thoughts and questions on inertia and static friction. It is common for students to have confusion or questions about these concepts, and I am happy to provide a response to your content.
First, let's clarify the concept of friction. Friction is the force that resists the motion between two surfaces in contact. It is affected by factors such as the roughness of the surfaces, the applied force, and the weight of the objects. The surface area of the objects does not directly affect friction, but it can indirectly impact it by increasing the contact area between the two surfaces.
In the case of nails becoming harder to pull out the deeper they are embedded in a surface, it is not the surface area that is causing the increased difficulty. Instead, it is the increased contact area between the nail and the surface, which leads to a larger frictional force. This is because the surface area of the nail that is in contact with the surface increases as it is embedded deeper, resulting in more points of contact and a larger frictional force.
Regarding your question about inertia, it is important to remember that inertia is a property of an object that resists changes in its motion. It is directly proportional to an object's mass, meaning that the more massive an object is, the greater its inertia. In the case of the nail, yes, it would technically have a larger inertia as it becomes embedded deeper in the surface because its mass remains the same, but its contact area and frictional force increase.
In conclusion, while the surface area does not directly affect friction, it can indirectly impact it by increasing the contact area between two surfaces. And even though inertia is solely dependent on mass, it is important to consider other factors, such as friction, when analyzing the motion of objects. I hope this helps clarify any confusion and provides a better understanding of these concepts.
Related to Inertia and static friction confusion
1. What is inertia?
Inertia is the tendency of an object to resist changes in its state of motion. This means that an object will continue to move at a constant velocity or remain at rest unless acted upon by an external force.
2. What is static friction?
Static friction is the force that prevents two surfaces from moving against each other when there is no relative motion between them. It is caused by the interlocking of irregularities on the surfaces and is always equal in magnitude to the force trying to initiate motion.
3. How are inertia and static friction related?
Inertia and static friction are both related to the resistance of motion. Inertia is the resistance to changes in motion while static friction is the resistance to initiating motion. Both of these concepts are governed by Newton's first law of motion, which states that an object will remain at rest or in motion with a constant velocity unless acted upon by an external force.
4. What causes confusion between inertia and static friction?
The confusion between inertia and static friction often arises because they both involve the resistance to motion. Additionally, both concepts are related to the force required to initiate or maintain motion. However, they are fundamentally different as inertia is an inherent property of an object while static friction is a force that acts between two surfaces.
5. How can I differentiate between inertia and static friction?
The key difference between inertia and static friction is that inertia is an object's tendency to resist changes in motion while static friction is the force that prevents two surfaces from sliding against each other. Additionally, inertia is an inherent property of an object while static friction is a force that is dependent on the surfaces in contact. Understanding these differences can help differentiate between the two concepts.
  • Mechanics
